Can't MKV a Blu Ray disc. Help plaese!
Mkvern
#1 Post by Mkvern » Fri Oct 28, 2016 7:21 pm
I've been able to rip many, but this 2016 Blu Ray Disc can't be ripped.
Any suggestion will be appreciated! Thank you!
Here is the info:
MakeMKV v1.9.7
OS device name: /dev/rdisk11
Product: BD-RE BE12LU38
Revision: 1.00
Serial number: K8LC54C2223
Firmware date: 2011-06-07 12:34:56
Bus encryption flags: 1F
Highest AACS version: 61
Disc Information
Label: BDROM
Timestamp: 2014-01-05 15:38:09
Data capacity: 23.20 Gb
Disc type: BD-ROM
Number of layers: 1
____________________________________________________________
DEBUG: Code 0 at T}F;]<CE9vJ9">%+u:213130766
DEBUG: Code 0 at WKQW^c9mbz:nV Ix+r:29395195
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:6ad32eb46dd66433:HL-DT-ST BD-RE BE12LU38 1.00'
DEBUG: Code 0 at WKQW^c9mbz:nV Ix+r:29396345
DEBUG: Code 4 at WKQW^c9mbz:nV Ix+r:121262647
Highest AACS version is v61 , MKB saved as /Users/josematos/Library/MakeMKV/MKB_v61_BDROM.tgz
DEBUG: Code 0 at 'V%sU:vm4=.PZ3z3:121264073
DEBUG: Code 0 at 'V%sU:vm4=.PZ3z3:29397403
Thank you,
Re: Can't MKV a Blu Ray disc. Help plaese!
#2 Post by Woodstock » Fri Oct 28, 2016 8:05 pm
MakeMKV v1.9.7
Current version is 1.10.2, which is almost a year newer than what you're running. It supports AACS through version 62.
Mkvern
#3 Post by Mkvern » Fri Oct 28, 2016 8:11 pm
Thank you very much, Woodstock!
Will update, then.
Will be back with the result.
