Fatal error has occurred. Program will now exit.
nathaniel7
Post by nathaniel7 » Tue May 04, 2010 5:43 pm
This was on Indiana Jones and the Kingdom of the Crystal Skull (Blu-Ray). Debug log attached. Thanks.
nathaniel7
Re: Fatal error has occurred. Program will now exit.
Post by nathaniel7 » Tue May 04, 2010 6:10 pm
Same title, different hard drive.
setarip_old
Post by setarip_old » Tue May 04, 2010 9:53 pm
Hi!
1) Have you tried cleaning your original BluRay disc?
2) Does your original BluRay disc play properly?
nathaniel7
Post by nathaniel7 » Wed May 05, 2010 3:19 am
setarip_old wrote:Hi!
Yes
setarip_old wrote:2) Does your original BluRay disc play properly?
Not sure yet, but others have caused fatal error but played fine.
setarip_old
Post by setarip_old » Wed May 05, 2010 3:33 am
And how were those resolved?
nathaniel7
Post by nathaniel7 » Wed May 05, 2010 6:44 pm
They were not, the disc is played instead of making MKV of them.
Attached is zip with .CLPI and .MPLS files from the disc.
nathaniel7
Post by nathaniel7 » Wed May 05, 2010 7:43 pm
Here is debug log of same title when I select Backup with Decrypt checked.
setarip_old
Post by setarip_old » Wed May 05, 2010 7:58 pm
Again, does your original BluRay disc play properly?
What Region is your original BluRay disc?
Have you succeeded in backing up (full backup or .MKV) ANY original BluRay discs with this same system?
nathaniel7
Post by nathaniel7 » Wed May 05, 2010 9:42 pm
setarip_old wrote:Again, does your original BluRay disc play properly?
I will check in a few.
USA.
Yes, many. A few have had this same issue including Avatar.
Post by mike admin » Thu May 06, 2010 6:28 am
Your logs indicate random corruptions in M2TS file. I would suggest that you have a general problem with your hardware, probably defective memory or over-clocking.
setarip_old
Post by setarip_old » Thu May 06, 2010 6:54 pm
@nathaniel7
Based on the insight offered by "mike admin", I'd suggest that you also check to see if your system is overheating...
nathaniel7
Post by nathaniel7 » Fri May 07, 2010 9:23 pm
mike admin wrote:Your logs indicate random corruptions in M2TS file. I would suggest that you have a general problem with your hardware, probably defective memory or over-clocking.
Hmmm...thank you for the suggestion.
My optical drives are on a PCIe SATA card with Sil3132 chipset. I did realize a new driver was available but it made no difference to the fatal error. The system is not overclocked or overheating, and the drive is relatively new. I will run some tests on the memory. The disc does indeed play fine. I have successfully converted many of my Blu-Rays with the same hardware configuration and various versions of MakeMKV. It works great with the exception of a couple discs offering only a fatal error
nathaniel7
Post by nathaniel7 » Sun May 23, 2010 7:07 pm
It turned out it was my Blu-Ray drive. 3 months old and it failed. Put in a different drive and all is well. Thanks Mike!
