Mike and Dave Need Wedding Dates - no FUTs generated
taseldor
US retail version. I e-mailed the .tgz dump file to svq@makemkv.com a few days ago -- anyone know how long it generally takes to update the SVQ (or whatever the terminology is?
Thank you.
Thank you.
ekael86
Re: Mike and Dave Need Wedding Dates - no FUTs generated
Still nothing.....I sent in the dump file awhile ago
turrentine87
09 October 2016
I'm Getting not FTU's found. After copying File is working but degraded.
Please update.
Thank you
I love your product.
Please update.
Thank you
Zonian
He's usually super quick getting the update out but I sent one on 10/5...
asr101
As Mentioned This disc does not work. It generates a file that is not watchable. Would be happy to send you logs or other info as needed.
ekael86
Looks like it's working now. Thanks!
mustachefart10
I'm having same issue with Netflix disc. I was not able to fully back up the disc. I'm able to generate MKV off of the title but it's extremely pixelated.
JohnnySoccer
The discs for Redbox have those errors and while it will rip, its not watchable.
bhampster
I used the "backup" option and hope it gets updated.
Papa007
Any update on this post? I'm trying to create a valid backup and keep getting the same error: no FUTs generated...
ssbrian
Same here - no FUTs generated...
johng
I'm getting the same error with my Netflix disc and emailed the dump.tgz file to the email address in the previous post on this thread.
outdoorguy568
On the RB version… if you want it in MKV format… rip it with ANY to an ISO, open it in CloneDrive, use MakeMKV to create an MKV formatted file via CloneDrive.
Works great on RB version and only has one MPLS (~25GB).
eisenb11
Any luck getting that to work?johng wrote:I'm getting the same error with my Netflix disc and emailed the dump.tgz file to the email address in the previous post on this thread.
johng
I just sent a 2nd dump file that was requested, and they said once they got that it shouldn't be long before it was fixed. Hopefully in the next day or so.
eisenb11 wrote:Any luck getting that to work?johng wrote:I'm getting the same error with my Netflix disc and emailed the dump.tgz file to the email address in the previous post on this thread.
