Application failed to initialize
sdkretschek
#1 Post by sdkretschek » Sun Oct 23, 2016 6:08 pm
OSX 10.11.5
makemkv 1.10.2
Never had an issue and started receiving this error message.
Restarted the mac, downloaded and installed 1.10.2. Same error message.
Re: Application failed to initialize
#2 Post by Woodstock » Sun Oct 23, 2016 10:25 pm
Do you have antivirus software installed?
Sometimes antivirus programs will give a false positive on parts of MakeMKV (this happens more on Windows than OS X), and it stops the program from starting.
Check the AV logs, if you do.
sdkretschek
#3 Post by sdkretschek » Sun Oct 23, 2016 11:08 pm
No anti-virus.
bq1533
#4 Post by bq1533 » Wed Oct 26, 2016 10:47 pm
I'm having the same issue, and I've never had an issue before. I also do not have anti-virus. Please help!
sdkretschek
#5 Post by sdkretschek » Wed Oct 26, 2016 11:32 pm
I downloaded the latest version running OS X 10.12 Sierra and had no issue, but I had no previous issues with 10.11.5.
bq1533
#6 Post by bq1533 » Wed Oct 26, 2016 11:33 pm
I found out the issue with my software. sdkretschek are you by chance getting a Coretelephony Trace File Error? If so, you need to clear this out before MakeMKV will work.
sdkretschek
#7 Post by sdkretschek » Wed Oct 26, 2016 11:39 pm
Where is the trace file error and do you simply delete the error file or delete the core telephony references within a trace file.
