Mike and Dave Need Wedding Dates - no FUTs generated
taseldor
Post by taseldor » Tue Oct 04, 2016 6:05 pm
US retail version. I e-mailed the .tgz dump file to svq@makemkv.com a few days ago -- anyone know how long it generally takes to update the SVQ (or whatever the terminology is?
Thank you.
ekael86
Re: Mike and Dave Need Wedding Dates - no FUTs generated
Post by ekael86 » Sat Oct 08, 2016 11:59 pm
Still nothing.....I sent in the dump file awhile ago
turrentine87
Post by turrentine87 » Sun Oct 09, 2016 6:35 am
09 October 2016
I'm Getting not FTU's found. After copying File is working but degraded.
Please update.
Thank you
I love your product.
Zonian
Post by Zonian » Sat Oct 15, 2016 6:01 pm
He's usually super quick getting the update out but I sent one on 10/5... :(
asr101
Post by asr101 » Sat Oct 15, 2016 8:58 pm
As Mentioned This disc does not work. It generates a file that is not watchable. Would be happy to send you logs or other info as needed.
ekael86
Post by ekael86 » Tue Oct 18, 2016 7:56 am
Looks like it's working now. Thanks!
mustachefart10
Post by mustachefart10 » Tue Oct 25, 2016 7:02 pm
I'm having same issue with Netflix disc. I was not able to fully back up the disc. I'm able to generate MKV off of the title but it's extremely pixelated.
JohnnySoccer
Post by JohnnySoccer » Tue Oct 25, 2016 7:08 pm
The discs for Redbox have those errors and while it will rip, its not watchable.
bhampster
Post by bhampster » Tue Oct 25, 2016 7:30 pm
I used the "backup" option and hope it gets updated.
Papa007
Post by Papa007 » Tue Oct 25, 2016 11:57 pm
Any update on this post? I'm trying to create a valid backup and keep getting the same error: no FUTs generated...
ssbrian
Post by ssbrian » Wed Oct 26, 2016 1:05 am
Same here - no FUTs generated...
johng
Post by johng » Wed Oct 26, 2016 3:01 am
I'm getting the same error with my Netflix disc and emailed the dump.tgz file to the email address in the previous post on this thread.
outdoorguy568
Post by outdoorguy568 » Wed Oct 26, 2016 4:32 pm
On the RB version… if you want it in MKV format… rip it with ANY to an ISO, open it in CloneDrive, use MakeMKV to create an MKV formatted file via CloneDrive.
Works great on RB version and only has one MPLS (~25GB). :D
eisenb11
Post by eisenb11 » Thu Oct 27, 2016 7:21 am
johng wrote:I'm getting the same error with my Netflix disc and emailed the dump.tgz file to the email address in the previous post on this thread.
Any luck getting that to work?
johng
Post by johng » Fri Oct 28, 2016 3:30 am
I just sent a 2nd dump file that was requested, and they said once they got that it shouldn't be long before it was fixed. Hopefully in the next day or so.
