Nerve 2016 Correct Playlist
hvnphoto
Post by hvnphoto » Sun Oct 16, 2016 6:39 pm
U.S. Retail
Title information
Source file name: 00887.mpls
Duration: 1:36:18
Chapters count: 16
Segment count: 15
Segment map: 517,509,507,503,511,508,510,514,505,501,506,512,515,502,504
File name: Nerve_t216.mkv
For those interested in this film. Thanks.
JohnnySoccer
Re: Nerve 2016 Correct Playlist
Post by JohnnySoccer » Tue Oct 25, 2016 4:36 pm
I checked the Redbox edition, and 887 playlist didn't match the segments you listed.
hvnphoto
Post by hvnphoto » Tue Oct 25, 2016 5:46 pm
Does any of the playlists match the segment map? Different disc versions usually have a different mpls. However, the segments are usually the same.
spas2k
Post by spas2k » Tue Oct 25, 2016 6:01 pm
The redbox version does not have a single playlist that starts with the segment 517.
bhampster
Post by bhampster » Tue Oct 25, 2016 7:33 pm
DVDFab said 887 was still correct (for redbox)
I used that and so far so good... Think I watched about an hours worth. Plan to watch it all tonite and see what's what.
I tried to use the "how to find correct mpls" post for find the correct mpls, but the version I have of PowerDVD 10 won't play this disc at all. (I know PowerDVD is up to 16 now... that's a version that came bundled with my external drive.)
seantnichols
Post by seantnichols » Tue Oct 25, 2016 9:33 pm
RB 887.mpls checks out. I manually watched the segments in order, they fit correct.
515,512,513,503,510,514,518,504,508,519,516,505,511,520,517,501,502,507
hvnphoto
Post by hvnphoto » Wed Oct 26, 2016 12:32 am
My bad for stating that the segments should match across all disc versions. Best manual method to determine the correct playlist is to open the BDMV folder and review the segments. The beginning and ending segments are easy to determine. If you view the ending of each segment you can determine the following segments. Piece the segments together and only 1 mpls will match. The entire process takes about 30 minutes or less.
Sorry, if I had the Redbox I would do it for you guys. For the time being I have access to the retail copies only and I normally post the correct playlist in advance of the Redbox copy.
Thanks.
seantnichols
Post by seantnichols » Wed Oct 26, 2016 4:38 am
hvnphoto, see my post above, I already did it on the redbox version. :)
tombutcher1990
Post by tombutcher1990 » Sun Jan 15, 2017 4:41 pm
Hi Guys,
Sorry to resurrect an old thread here, but has anyone got the correct info for the UK/Europe version of this disc? The info here doesn't match what I'm seeing on my disc.
TIA!
irajames
Post by irajames » Sun Mar 26, 2017 7:48 am
For anyone else wondering it is 887 mpls on Netflix also!
annevejb
Post by annevejb » Sat Apr 29, 2017 4:17 pm
I also have a European disk. There is no 887mpls. The lists all start with 516, not 515. For replay I use VLC, and I could get it to play on VLC, the feature had some out of sequence shots but was still rather okay. To do better I would need to switch to Windows and a commercial player, if think that there is only one available now?
My copy of MakeMKV does identify a stream as the main feature, 00997mpls, 1:36:18. It is looking good.
mgutt
Post by mgutt » Mon Jan 13, 2020 8:46 pm
I have the German Blu-Ray. It contains two playlists. 00021.mpls and 00022.mpls. The correct one is 00021.mpls as this contains burned-in german texts like at timestamp 01:41.
2020-01-13 21_45_25.png (320.54 KiB) Viewed 30952 times
bluray97
Post by bluray97 » Wed Nov 06, 2024 12:39 am
Hu guys,
Anything for the Canadian version?
I tried Java Runtime and Get MPLS without any clear winning playlist.
j-h-s
Post by j-h-s » Sun Sep 28, 2025 11:43 am
Backed up the disc, then ran it through
makemkvcon.exe -r --cache=1024 info disc:0 > c:\output.txt
or
makemkvcon.exe -r --cache=1024 info file:pathTOindex.bdmv > c:\output.txt
Opened the txt file, kept searching for each part building a longer comma separated search while watching the segments to see where they ended/started
516,505,509,524,519,522,511,518,515,510,523,501,504,502,506
997 - uk
