50% Error Rate
lavadvdlamp
50% Error Rate
Post by lavadvdlamp »
Newish to this process and have been hitting around 50% error rates with Blue Ray DVD. I have attached latest Log from a failed attempt.
Running Fedora 24 on i7Nuc with Samsung BDDVDW SE-506CB TS02
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '151973888'
I have rebooted, cleaned disc, and attached to external powered USB hub as troubleshooting.
Debug log started at Mon Oct 24 20:09:11 2016 , written by MakeMKV
v1.10.2 linux(x64-release)
001005:0000 MakeMKV v1.10.2 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as
/home/lavajgh/MakeMKV_log.txt
DEBUG: Code 2147483648 at 1!>*=,~!{9fSK;|9:121265315
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=NbNpu1G6RyquI88Iq33h/p+cCKsRB9MJujaOCEyPE8FSxL8L5TVKRG4CRGCJUqDyqor+X9tfIjQoBihO+uBiP/pAhObNaBZlmUpqMhlqrBEKYSMbVAlywluTSUMMxKM2iU/BgwyX6LyWGuAV1QyznIbTt0ZXPT0WZA==
DCE=TE0Onm3108dCGWM6uvWNDNNPdBDhIKlNDM2/0+ZmGGDNJUu8ViPV9guY4x/6K28PAlwSGK7x4eMGMxR+JTaayzQR9VPDfofszY1BqGfwAzFvod7d8NkBtoXGcDAhSZTRrezbizhiyEMCtgDPSR1kMXe0dYimUfhzxg==
001003:0020 DEBUG: Code 0 at la/Qm*#q{:#66GZz#'GAaGn:213130122
DISCID=E01AE2316E99FF8E81968F0A23384E92A6844A4F
001003:0020 DEBUG: Code 2048 at 7eIj}e YKrTXOF4?:29402601
003307:0000 File 00800.mpls was added as title #0
003307:0000 File 00402.mpls was added as title #1
003307:0000 File 00401.mpls was added as title #2
003025:0000 Title #00020.mpls has length of 38 seconds which is less
than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00099.mpls has length of 40 seconds which is less
003025:0000 Title #00100.mpls has length of 40 seconds which is less
003025:0000 Title #00021.mpls has length of 58 seconds which is less
003025:0000 Title #00650.mpls has length of 30 seconds which is less
003307:0000 File 00496.mpls was added as title #3
003307:0000 File 00257.mpls was added as title #4
003307:0000 File 00600.mpls was added as title #5
003025:0000 Title #01000.m2ts has length of 45 seconds which is less
003025:0000 Title #01001.m2ts has length of 45 seconds which is less
003025:0000 Title #00011.m2ts has length of 26 seconds which is less
003025:0000 Title #00022.m2ts has length of 38 seconds which is less
003025:0000 Title #01002.m2ts has length of 26 seconds which is less
003025:0000 Title #01003.m2ts has length of 26 seconds which is less
003307:0000 File 00800.m2ts was added as title #6
003307:0000 File 00250.m2ts was added as title #7
003025:0000 Title #00095.m2ts has length of 29 seconds which is less
003025:0000 Title #00096.m2ts has length of 11 seconds which is less
003025:0000 Title #00097.m2ts has length of 29 seconds which is less
003025:0000 Title #00098.m2ts has length of 11 seconds which is less
003025:0000 Title #00000.m2ts has length of 0 seconds which is less than
003025:0000 Title #00023.m2ts has length of 58 seconds which is less
003025:0000 Title #01028.m2ts has length of 30 seconds which is less
003025:0000 Title #01029.m2ts has length of 30 seconds which is less
003025:0000 Title #01030.m2ts has length of 30 seconds which is less
003025:0000 Title #01031.m2ts has length of 30 seconds which is less
003025:0000 Title #01032.m2ts has length of 30 seconds which is less
003025:0000 Title #01033.m2ts has length of 2 seconds which is less than
003025:0000 Title #01034.m2ts has length of 2 seconds which is less than
003025:0000 Title #01035.m2ts has length of 2 seconds which is less than
003025:0000 Title #01036.m2ts has length of 2 seconds which is less than
003307:0000 File 01048.m2ts was added as title #8
003307:0000 File 01049.m2ts was added as title #9
003307:0000 File 01050.m2ts was added as title #10
003307:0000 File 01051.m2ts was added as title #11
003307:0000 File 01052.m2ts was added as title #12
003307:0000 File 01053.m2ts was added as title #13
003307:0000 File 01054.m2ts was added as title #14
003307:0000 File 01055.m2ts was added as title #15
003307:0000 File 01056.m2ts was added as title #16
003307:0000 File 01057.m2ts was added as title #17
003025:0000 Title #01058.m2ts has length of 57 seconds which is less
003025:0000 Title #01059.m2ts has length of 95 seconds which is less
003025:0000 Title #01060.m2ts has length of 65 seconds which is less
003025:0000 Title #01061.m2ts has length of 77 seconds which is less
003025:0000 Title #01062.m2ts has length of 62 seconds which is less
003025:0000 Title #01063.m2ts has length of 118 seconds which is less
003025:0000 Title #01064.m2ts has length of 83 seconds which is less
003307:0000 File 01065.m2ts was added as title #18
003025:0000 Title #01066.m2ts has length of 111 seconds which is less
003025:0000 Title #01067.m2ts has length of 2 seconds which is less than
003025:0000 Title #01068.m2ts has length of 30 seconds which is less
003025:0000 Title #01069.m2ts has length of 2 seconds which is less than
003025:0000 Title #01070.m2ts has length of 2 seconds which is less than
003025:0000 Title #01071.m2ts has length of 2 seconds which is less than
003025:0000 Title #01072.m2ts has length of 2 seconds which is less than
003025:0000 Title #01073.m2ts has length of 2 seconds which is less than
003025:0000 Title #01074.m2ts has length of 2 seconds which is less than
003025:0000 Title #01075.m2ts has length of 2 seconds which is less than
003025:0000 Title #01076.m2ts has length of 2 seconds which is less than
003025:0000 Title #01077.m2ts has length of 2 seconds which is less than
003025:0000 Title #01078.m2ts has length of 2 seconds which is less than
003025:0000 Title #01079.m2ts has length of 2 seconds which is less than
003025:0000 Title #01080.m2ts has length of 30 seconds which is less
003025:0000 Title #01081.m2ts has length of 30 seconds which is less
003025:0000 Title #01082.m2ts has length of 30 seconds which is less
003025:0000 Title #01083.m2ts has length of 30 seconds which is less
003025:0000 Title #01084.m2ts has length of 30 seconds which is less
003025:0000 Title #01085.m2ts has length of 4 seconds which is less than
005014:0000 Saving 1 titles into directory
/home/lavajgh/Plex/Movies/Blue Ray/Shrek
001003:0020 DEBUG: Code 1073741829 at D9C!l9F"A]Aw2XwG:29393953
001003:0020 DEBUG: Code 100864261 at G|QJq"~dMr`L/M=S:121269731
001003:0020 DEBUG: Code 4092 at 7eIj}e YKrTXOF4?:29402601
002003:0000 Error 'Posix error - Input/output error' occurred while
reading '/dev/sr0' at offset '151973888'
DEBUG: Code 1073741829 at t_H@MI.w $wuzR(UPq:213130904
reading '/dev/sr0' at offset '151980032'
reading '/dev/sr0' at offset '151986176'
reading '/dev/sr0' at offset '151992320'
001003:0020 DEBUG: Code 2044 at 7eIj}e YKrTXOF4?:29402601
occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '152238080'
occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '152502272'
occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '153092096'
occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '153221120'
occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '153743360'
occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '154007552'
reading '/dev/sr0' at offset '154007552'
002003:0000 Error 'Internal error - Operation was cancelled (112)'
001003:0020 DEBUG: Code 0 at 5g^^H?_b/Sv%"fu$[.T|:121263291
001003:0020 DEBUG: Code 0 at 46UD|Ak>LAkBogD,9b!R:121262302
001003:0020 DEBUG: Code 0 at 5g^^H?_b/Sv%"fu$[.T|:213130812
001003:0020 DEBUG: Code 2172351 at 5g^^H?_b/Sv%"fu$[.T|:29393286
001003:0020 DEBUG: Code 0 at zr1{B}-:)8ci2vX$C[wO^:29398967
005003:0000 Failed to save title 0 to file
/home/lavajgh/Plex/Movies/Blue Ray/Shrek/Shrek_t00.mkv
Re: 50% Error Rate
Do you have access to another drive to test?
"MEDIUM ERROR:L-EC UNCORRECTABLE ERROR" is a report from the drive to the operating system (and then to MakeMKV) saying that the disk was unreadable at the point shown. You've covered the majority of the reasons why it could be happening, which leaves the drive.
But I'd try cleaning the disk again, because bad drives are really a lot more rare than a bit of haziness on the disk. Especially if the location of the error moves a bit between attempts. It may help to increase the error retry count above the default of 5.
