Editing MKV files in Adobe Premiere
monkeyhead
Not sure if this is a common problem or not, but I've got to pull about 14 minutes out of an hour and a half long DVD. I've got Adobe Premiere but I can't seem to get the MKV format to show up in my workspace. Conversion worked fine, no problem, but I can't get into it to cut what I need. Is there a step I'm missing out on? The end goal is to make a DCP file of several things.
Re: Editing MKV files in Adobe Premiere
When I need to cut a part of a MKV I use the MKVToolnix program: I load the mkv file and using the "splitting" I remove the parts I don't need. As no recodificación of audio and vídeo is needed, the process is quite fast.
If I understand correctly, you want to edit an .mkv file in Adobe Premier, correct? If yes, .mkv is not a format natively supported by AP. https://forums.adobe.com/thread/2068738monkeyhead wrote:Not sure if this is a common problem or not, but I've got to pull about 14 minutes out of an hour and a half long DVD. I've got Adobe Premiere but I can't seem to get the MKV format to show up in my workspace. Conversion worked fine, no problem, but I can't get into it to cut what I need. Is there a step I'm missing out on? The end goal is to make a DCP file of several things.
Help Keep MakeMKV Going - http://www.makemkv.com/buy/
Latest Beta Key - http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Multiple Playlists? - http://www.makemkv.com/forum2/viewtopic ... 6&start=15
