Blood Father - Netflix USA
Anyone know which segment map is correct for Netflix release of Blood Father? The other post about the retail version doesn't match the Netflix configuration.
Re: Blood Father - Netflix USA
Hi, I got the same title as the first post for the netflix USA blu ray of this title.
netflix
blood father
TITLE: 00388.mpls
0503, 00507, 00509, 00511, 00513, 00508, 00518, 00515, 00505, 00512, 00519, 00520, 00517, 00501, 00516, 00514, 00502, 00506, 00504, 00510
netflix
blood father
TITLE: 00388.mpls
flintstone198 wrote:Hi, I got the same title as the first post for the netflix USA blu ray of this title.
netflix
blood father
TITLE: 00388.mpls
My Netflix USA Bluray doesn't even have a title 388, and the ones around it have a different segment order...
Never mind! I found it! SOmehow it was out of order
If you don't see the the correct segment map (00388.mpls), just be sure to check that MakeMKV hasn't "auto-selected" that segment map and placed it at the very top of the list. It may have "Main Feature" listed next to it. This isn't always the case, but just thought I would throw that advice into the hat. Hope it helps!
EDIT: Looks like you figured it out before I even finished typing my reply!
Hey good find! I was looking all over for 388.ekael86 wrote:If you don't see the the correct segment map (00388.mpls), just be sure to check that MakeMKV hasn't "auto-selected" that segment map and placed it at the very top of the list. It may have "Main Feature" listed next to it. This isn't always the case, but just thought I would throw that advice into the hat. Hope it helps!
