LG49UB830V: 3D BlueRay Rip shown only 2D
Zonk112
#1 Post by Zonk112 » Sat Oct 15, 2016 2:20 pm
I am new to the Board and currently on trial with MakeMKV.
I have a couple of 3D movies which I would like to transfer (losless) to MKV. In the past I've tried the Ripper Option of a "certain Software with a Monkey Icon" (I'm not sure if it's allowed to say the name) but each time I tried to convert 3D movies my sound wasn't synchonous anymore - no idea why.
So I made a research and found MakeMKV. My first impression was great, Surround Sound remains in the file, 3D is ripped losless.
Even if the software seems to be pretty simple in use, I followed the recommendation on http://movie-tips-review.blogspot.de/20 ... ll-hd.html
Therefore I activated the MVC checkbox at "Video" to get a real losless copy.
My first file was more than 30GBs so i thought everything went fine.
I had a look into MediaInfo and it also looked great:
Format : AVC
Format/Info : Advanced Video Codec
Format-Profil : Stereo High@L4.1 / High@L4.1
MultiView_Count : 2
First I've tested the file on my PC using VLC but this was my first disappointment... The movie seemed to be 2D. OK, quick research, obviously if MVC is active the resulting file is not SBS or top/bottom, due to the losless transfer, it's framepacked like a real physical BR Disc. And VLC seems to be overwhelmed with this. My mood was getting cheerful once again and i decided to make some further tests. First I took this BR Disc into the BR Player and watched the beginning without glasses to recognize how "strong" the 3D effect is causing shifts, as a comparsion.
To avoid any LAN bandwith issues I moved the file on an USB stick and inserted it to my LG49UB830V, hopefully it starts right away with the 3D prompt to eliminate all my doubts. I started the movie but it was 2D :?
I pressed the 3D button and took all available modes (This picture is from google, so ignore the PS3 background, I just want to show the LGs 3D Options http://bilder.hifi-forum.de/medium/7618 ... 290497.jpg My TV got Option 1 / 2 / 3 / 4 / 6 / 7, Option 5 is not there for me btw) but nothing happend.
SBS and T/B doesn't work at all, but this was pretty clear since my file seems to be framepacked. But even the other ones didn't help. OK, 2D --> 3D worked, or let's say: It did something like that. I had a 2D view converted to 3D, the 3D effect and the shift between the 2 pictures was.. i don't know 10% of the original one.
OK, can someone maybe help me? Did I misconfigure something? Is my TV not able to read the files properly? How can I rip 3D BRs to 3D MKV and ensure that...
... real 3D is active
... the Surround sound remains
... the transfer was losless to avoid any quality - loss?
Thanks and have a nice weekend
Re: LG49UB830V: 3D BlueRay Rip shown only 2D
#2 Post by Woodstock » Sat Oct 15, 2016 4:52 pm
VLC isn't going to display 3D because it isn't a 3D-aware application. There are a limited number of 3D software players.
3D-aware BD players are not necessarily going to handle 3D in an MKV file.
There are other discussions on 3D and MKV files in the forum, but you can't search on words smaller than 4 letters, so "3D MVC" doesn't find anything...
But one recent thread can be found here: http://makemkv.com/forum2/viewtopic.php?f=1&t=7357
Zonk112
#3 Post by Zonk112 » Sun Oct 16, 2016 8:35 am
So is there in general no way to get a loless MKV (or any other file-format) out of a BR Disc or is it just MakeMKV?
#4 Post by SamuriHL » Mon Oct 17, 2016 1:17 pm
That's not what he said at all. MakeMKV creates a lossless 3D MKV just fine. He said your chosen player doesn't know how to play it. That's not a MakeMKV problem. You're going to need something that knows how to handle 3D in an MKV format, which is definitely possible. Look up madvr/lav filters to get you on the right path.
