Issue with Star Trek TNG Season 3, Disc 1, Episode 1
AndyMac
Post by AndyMac »
I'm getting an error ripping the first episode of this disc. I tried playing it in my BluRay player and there didn't appear to be any issues so I suppose I can't try to get a replacement disc. Can someone tell me if these errors are physical issues with the disc or something else?
MakeMKV v1.10.2 win(x64-release) started
Title #00019.mpls has length of 286 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00011.mpls has length of 286 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00010.mpls has length of 33 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00009.mpls has length of 34 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00008.mpls has length of 34 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00007.mpls has length of 34 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00006.mpls has length of 34 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00014.mpls has length of 1061 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00013.mpls has length of 172 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00081.mpls has length of 20 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00080.mpls has length of 41 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
File 00005.mpls was added as title #0
Title #00079.mpls has length of 41 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
File 00004.mpls was added as title #1
File 00003.mpls was added as title #2
File 00002.mpls was added as title #3
File 00001.mpls was added as title #4
File 00000.mpls was added as title #5
Title #00073.mpls has length of 15 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00081.m2ts has length of 144 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00066.m2ts has length of 11 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00005.m2ts has length of 0 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00056.m2ts has length of 140 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00064.m2ts has length of 0 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00053.m2ts has length of 32 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00052.m2ts has length of 34 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00025.m2ts has length of 19 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00051.m2ts has length of 34 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00024.m2ts has length of 29 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00050.m2ts has length of 34 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00023.m2ts has length of 29 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00049.m2ts has length of 34 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00022.m2ts has length of 10 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00021.m2ts has length of 10 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00020.m2ts has length of 10 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00019.m2ts has length of 10 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00018.m2ts has length of 10 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00017.m2ts has length of 10 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00016.m2ts has length of 10 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00015.m2ts has length of 10 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00014.m2ts has length of 10 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00013.m2ts has length of 10 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00012.m2ts has length of 10 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00010.m2ts has length of 16 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00048.m2ts has length of 140 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00065.m2ts has length of 0 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00040.m2ts has length of 96 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00006.m2ts has length of 75 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00054.m2ts has length of 1061 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00063.m2ts has length of 11 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00062.m2ts has length of 0 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00007.m2ts has length of 0 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00080.m2ts has length of 144 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00069.m2ts has length of 5 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00068.m2ts has length of 300 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Saving 1 titles into directory D:/Rips/1.Ripped using profile 'WDTV' from file 'C:\Program Files (x86)\MakeMKV/wdtv.mmcp.xml'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '3634753536'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '3634753536'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '3634757632'
Failed to save title 4 to file D:/Rips/1.Ripped/Star_Trek_The_Next_Generation_Season_3_Disc_1_t04.mkv
0 titles saved, 1 failed
Re: Issue with Star Trek TNG Season 3, Disc 1, Episode 1
Just because it will play in a device that is programmed to ignore errors doesn't mean it doesn't have a problem.
First try cleaning the disk. A lot of disks I've received this year have had some sort of chemical film on them that made them difficult to read unless they were washed first. The errors would move around, depending on which drive I was ripping in, but they always failed at some point.
If that doesn't fix it, request a replacement disk - I haven't had a vendor refuse to replace a disk I wasn't able to read.
I'm making the assumption that you're using an internal SATA drive to read this. Some USB drives will have issues with power when the disk starts spinning fast, but the first episode is not usually one that will be out where the disk spins fast.
AndyMac
Post by AndyMac »
I have cleaned it, first with a microfiber cloth but now with dish detergent and microfiber. It seems to fail at different locations even in the same drive.
It is an internal SATA drive under Windows 10. I ripped every other disc in the set without any issues though some ripped very slowly.
When I contact the vendor do I just say it won't play or do I say it won't rip to my media player? I want to be honest but not too honest :).
I just wanted to make sure this wasn't some issue that an updated SVQ (is that right) wouldn't correct.
Thanks for your help.
If the failures occur at different locations, you MIGHT be able to increase the retry count ( Preferences->IO ) and get by.
I had an issue with a disk a month ago. Contacted the vendor and said, "Disk 2 failed to read episodes 1 and 3 in three different players. How can we get it replaced so that I can watch all of the series?" I had a bit more trouble on that one than usual, since I had received mine 3 weeks before the release date, so I couldn't get the replacement until it was officially released, but they took care of it.
If it's a problem with copy protection of some kind (including BD+), you should get a different progression of errors. SCSI/POSIX errors are almost always a disk issue.
