Replacement key required for installation on new laptop
rizzy
Post by rizzy » Sun Oct 09, 2016 6:08 pm
Hello.
Could I get a replacement key for installation on a new laptop.
I've tried using the current key but it does not appear to work.
Thanks.
Rizwan
yorgo
Re: Replacement key required for installation on new laptop
Post by yorgo » Sun Oct 09, 2016 6:23 pm
Did you purchase a key or are you looking for the free beta key?
rizzy
Post by rizzy » Tue Oct 11, 2016 6:18 pm
I'm pretty sure I purchased the product a couple of years ago but can't seem to locate the email from makemkv.
I think I may have used a now defunct email address so I do not have the original key. But my registered name should match up as a paid user.
Post by Woodstock » Tue Oct 11, 2016 8:49 pm
If you had a purchased key, start by checking your email for a message from customer@avangate.com, the payment processor Mike uses.
If you can't find that, send an email to support@makemkv.com with your information, and he can pull up the key from his records.
For obvious reasons, that is ONLY done via email. :)
