Suggestion for the Mac OS X version of MakeMKV
horkonpon
Post by horkonpon »
When MakeMKV is not capable to rip a BR, he make an TGZ file with the information of the BR to send to you to make the SVQ file. It's Ok, but there is a problem. The TGZ file is created in the folder Users/<user_name>/.MakeMKV that is a hidden folder by default, so its necessary to open the terminal to make the hidden files and folders visibles, copy the file in other location and return to terminal window to hide the files and folders again.
So it would be a good idea to put the TGZ file in a non hidden folder.
Thanks in advance
Greetings
Alberto
Re: Suggestion for the Mac OS X version of MakeMKV
Preferences->General
Set the MakeMKV data folder to a path that is visible to Finder.
That will be where MakeMKV stores all further files, and you can also put custom profile XML files in that directory, so that they stay safe across version updates.
horkonpon
Post by horkonpon »
Thanks for the information. I change the folder in preferences but it hasn't take effect until I have erased the previous folder .MakeMKV :shock: :shock:
Now it works fine
Thanks a lot
Regards
Alberto
