Frozen (Scandinavian edition) Seamless branching
skumlos
Post by skumlos »
I hope this is the correct category, but I've bought MakeMKV to use on linux with Kodi, which for most of the time works great! However on a disc like Frozen, I run into issues. On Windows with AnyDVD HD, I could usually choose multiple video titles, all related to the large amount of seamless branching versions it contains (English, Danish, Swedish etc.) where small parts of the movie is changed to include regional differences. With MakeMKV I only have the primary English one (Title 800), which as such is also fine, as it plays fine, with english language. However as soon as I change the language to Danish (DTS) things start to get out of sync (rather fast), and its quite easy to notice that it must be around where the seamless branching kicks in. Is there any way to get around this? Is it even possible to watch the "correct" title with MakeMKV?
NOTE: I use the system where libaacs.so.0 and libbdplus.so.0 are linked to libmmbd.so.0 to have direct playback through Kodi.
Re: Frozen (Scandinavian edition) Seamless branching
Post by mike admin »
Do you get the behaviour when making MKV file ( watching MKV file Produced by MakeMKV)? If yes, then please enable "log debug messages" and "show A/V synchronization issues" in preferences and post the log file. If not, then this is Kodi issue.
skumlos
Post by skumlos »
Hi Mike,
Thank you for your reply. I have not tried to make a mkv with it no, so I'll try to give it a spin and see what happens. How about the "missing" titles? Is it not possible to generate the "other" playlists or whatever they're called?
