MakeMKV 1.9.10 registration key fail to activate
Fr4gMovi3
Post by Fr4gMovi3 »
Hello!
I want to use MakeMKV 1.9.10 but there is a problem
When i try to run i get "This application is too old!",
If i type an registration key (i get it from this forum) i see "Thank you!" prompt then program closes.
When i try to launch it again it says "Key is expired"
Please provide me correct registartion code
Thank you! :)
Re: MakeMKV 1.9.10 registration key fail to activate
Periodically check this message: http://makemkv.com/forum2/viewtopic.php?f=5&t=1053
That is where the latest beta key will always be posted, and it includes the month when it expires.
And this is the current "complain about no new beta key" topic: http://makemkv.com/forum2/viewtopic.php?f=1&t=15177
