Popcorn A200 and MKV: Part II
philnort
#1 Post by philnort » Sun Apr 18, 2010 2:01 pm
However, using MakeMKV only my std definition DVDs have excellent functionality, eg. chapters, subtitles, etc. BD .MKVs will routinely freeze when skipping chapters (audio continues, but video freezes at start of chapter); similarly, MKV PGS subs can be problematic ...they don't appear as Hi-def images as when rendering .TS PGS subs.
Are these issues still to be worked out with Popcorn and the mkv container format? Anyone ?
I believe I've definitely found the solution to my particular problem thanks to the discussion re: the LG hardware players and video codecs. Repeated testing has led me to the following conclusion. Any BD using the VC-1 codec produces navigation problems with the Popcorn, i.e. as stated above, the unit will freeze on the video when navigating chapters, etc.
HOWEVER, if the video codec was .H264 >> NO PROBLEM at all, does NOT matter the size of the file, bitstream rate, etc....perfect. Therefore, I now pre-test with BDInfo..if the codec is .H264 I use the excellent MakeMKV. If VC-1, on to TSMuxer.
avaadore
Re: Popcorn A200 and MKV: Part II
#2 Post by avaadore » Tue May 04, 2010 7:46 am
hope there will be a fix for this, this is the only thing from stopping me buying makemkv :)
NomadCF
#3 Post by NomadCF » Tue May 04, 2010 11:49 am
