UPDATE: New BD+ as found in avatar
Tommye1078
Re: UPDATE: New BD+ as found in avatar
Hey guys
I'm a idiot. I was trying to point the directory at the SVQ file and not a created SVQ directory folder. Sorry for the wasted posts.
setarip_old
No harm, no foul - Congratulations ;>}
pippit2
can u help me i am new at this i dont know how to set up makemkv prefences up like what to put in aacs and bd+ thank you pippit2
indica
Ive tried to mkv the entire disc and use a couple of different players and I cannot get the language translation to appear when the scientists in avatar speak the alien language. Does anyone else have this issue or does MKV have a solution?
Thank you
Thank you
NomadCF
Did you convert the subtitles or are they still in there still original PGS ?
indica
I just used mkv and converted the entire disc subtitles as well. I cant get ANY subtitles to show so I must be doing something wrong? This is the first disc I have ever had this problem with.
Tommye1078
^ +1
I had the same problem. Couldn't get the subtitles to display. I found a .srt file with the right timing and am using that. If you figure out how to get the subtitles form the avatar Blu Ray to work I would love to hear how you did it.
skittle
Your player needs to support PGS subtitles in MKV. Not many do (yet).
Either use the premade SRT, or convert the PGS to SRT/ASS/SSA, or get a player that supports PGS in MKV.
indica
OK I see I was reading about that but I wasnt sure and wanted to eliminate that it could be the mkv rip.
Thank you.
Thank you.
Muzer
I think you select the folder itself, not the actual sqv file - the intention being that if you need more (eg disc-specific) sqvs in the future you can put them all in one place and don't have to point it to each one individually.
mnfish
OK..So I'm totally lost. How do you save the avatar link to a file in the MakeMKV Folder? I've downloaded the 1.5.5 version. It won't let me save that link in a file. It just asks what program you want to open it with? What am I missing?
mnfish
benchmarkjoe
Thanks you for your hardwork. Finally I did rip the Avatar.
JohnWB
Well I have been tring various things but I keep getting
MakeMKV v1.5.5 beta win(x86-release) started
I am using XP Pro sp3
I made a directory called MakeMKV FilesSVQ & placed the avatar.svq file in there & pointed the program to it but no difference.
The iso file is called avatar.iso
Is there anything else that I can do please
ds2249
MakeMKV can only get the decryption keys from a real disc. You can not use an ISO file created by some other tool. Please try again with a physical disc.JohnWB wrote:Well I have been tring various things but I keep getting
