X-Men Apocalypse: no FUTs are created
I was trying to create mkv.file from X-Men Apocalypse 00800.mpls with 1.10.2
After reading content errormessage poped up
BD+ Code has been progressed, but no FUTs has been created. This could force errors...
BD+ Code wurde bearbeitet, aber es wurden keine FUTs erstellt. Dies kann zu Fehlern führen.
After creating mkv.-file massive compression artifacts are visible.
Any reports?
BR gt
Any reports?
BR gt
Re: X-Men Apocalypse: no FUTs are created
Did you click on the link that was there when you got the NO FUTs message, to report the new BD+ to Mike?
If not, there should have been a .tgz file created in your MakeMKV data directory that needs to be sent to svq@makemkv.com .
Additional details here: /svq/
Hi...
unfortunately there was no link to report to mike..![Sad :-(](./images/smilies/icon_sad.gif)
And I'm not been able to upload the pic due to "Sorry, the board attachment quota has been reached."
i have exactly the same problem and i've sent the dump file to the email address
Pictures don't help. As explained in the link, we know what happens when it BD+ happens.
For future reference, your MakeMKV data directory (Preferences->General) should have a copy of the file that can be sent after the fact.
Thanks, Sereby, for sending the file.
The german version of "X-Men: Apocalypse" makes the same problem. I have sent in the .tgz-file ![Wink ;)](./images/smilies/icon_wink.gif)
same Problem, german 2D and 3D .
Same Problem here, also a german 2D Blu-ray. - Send the file.
I have the same problem with the spanish version of this BR
I can't send the TGZ file generated by MakeMKV. I have tried with Yahoo Mail and Gmail and both block the TGZ file because of a (false) virus.
How can I send to you the TGZ file?
Thanks in advance
Best regards
Alberto
Thanks in advance
Best regards
Alberto
At this point, Mike should have enough to make the SVQ file. However, if you have somewhere that you can upload it to temporarily, and send Mike a download link at the same address, that works too.
Ok, I'll try itWoodstock wrote:At this point, Mike should have enough to make the SVQ file. However, if you have somewhere that you can upload it to temporarily, and send Mike a download link at the same address, that works too.
And finally I do it. I have sent the linkhorkonpon wrote:Ok, I'll try itWoodstock wrote:At this point, Mike should have enough to make the SVQ file. However, if you have somewhere that you can upload it to temporarily, and send Mike a download link at the same address, that works too.
![Very Happy :D](./images/smilies/icon_biggrin.gif)
Thanks for your job
Alberto
Hi All
I've got the same problem with trying to convert the X-Men Apocalypse Blu-ray (Region B) with "no FUTs are created", I have no doubt Mike is onto this issue. I have not found another video converter that is so well supported and also a one that has such a great open forum where users of this software can get great help and support.
Thanks allhttp://www.makemkv.com/forum2/postin ... 1649cae49#
Now the german version works fine. Thanx a lot! ![Wink ;)](./images/smilies/icon_wink.gif)
Anyone having any luck with the American version?
