The source file '/BDMV/STREAM/00017.m2ts' is ...
rickyhorror
Post by rickyhorror »
The source file '/BDMV/STREAM/00017.m2ts' is corrupt or invalid at offset 987199488, attempting to work around etc etc
Then... fatal error and program has to close, or it just freezes and I have to force close.
004004:0000 The source file '/BDMV/STREAM/00017.m2ts' is corrupt or invalid at offset 987199488, attempting to work around
tp=PZdlDoq8vQ9s4XD5I/zI9gOql8I98SxyVlnKrXc+nOj5wXwl0Db22SGG3jaYjxF/kXzK11OdZle6ndLG/AFHwltApIM11OaXGp/+JNXjGEVhq+/d+rjzEPEgZ/BKauzKzLbqH5McggkOuiJ7f69N0TOFXg/qQ6QMNp/mjNAx1Xwft4Ravtq6HLITq/pR1YiK4znfhffOmghSDNQd9ldgshHznG3ZjeCD65cNxU7Ij5YNk5l1v1Po00j2Q/64=
001003:0020 DEBUG: Code 0 at zjJ4tTzD?zIb*hXiSG\):121262647
tp=PYjmEVWXZQ6KvL0PbOFw+SP8yPYDqpfCPfEsclZZyq13Ppzo+cF8JdA29tkhht42mI8Rf5F8ytdTnWZXup3SxvwBR8JbQKSDNdTmlxqf/iTV4xhFYavv3fq48xDxIGfwSmrsysy26h+THIIJDroie3+vTdEzhV4P6kOkDDaf5ozQMdV8H7eEWr7auhyyE6v6UdWIiuM534X3zpoIUgzUHfZXYLIR85xt2Y3gg+uXDcVOyI+WDZOZdb9T6NNI9kP+u
tp=P+2djhF5SVROi5Xl4OhB+nR1QhQAbj6uOVIWNpRu+vdbNYTErp2FmOtNM8WZo+FnEfs69c3YJblqz6gUUiEbR5vy/PgioVaoIlqxbvTYbjZZ6NApRpFlwRMDbajRuAzbTGVbcPwOl8G9gzeiVaHGJ3FixDfL7+VyG9B2biURBIvQLsW4B2a2jn5eFOy5TZCbeJNlq8NvTveHZyYXc3MPfTfBknzyZbx/jzsrhUP33pzhszLVGXcngB32ZydI=
tp=PGyhma/tnY4ReUlUTouV5eDoQfp0dUIUAG4+rjlSFjaUbvr3WzWExK6dhZjrTTPFmaPhZxH7OvXN2CW5as+oFFIhG0eb8vz4IqFWqCJasW702G42WejQKUaRZcETA22o0bgM20xlW3D8DpfBvYM3olWhxidxYsQ3y+/lchvQdm4lEQSL0C7FuAdmto5+XhTsuU2Qm3iTZavDb073h2cmF3NzD303wZJ88mW8f487K4VD996c4bMy1Rl3J4Ad9mcnS
The disc plays perfectly fine, I've watched it completely to make sure of this. It's also brand new.
There are 8 episodes on this disc, and I only have issues ripping 2 of them.
The other 20 Episodes were already ripped from discs 1 and 2 with no issues.
Code when starting the rip:
FFENC003: option compression_level=5
FFENC004: option compression_level=5
FFDEC001: [truehd @ 000000a59816a250] Warning: not compiled with thread support, using thread emulation
FFDEC002: [truehd @ 000000a59888ea00] Warning: not compiled with thread support, using thread emulation
FFENC003: [flac @ 000000a5967568f0] Warning: not compiled with thread support, using thread emulation
FFENC003: [flac @ 000000a5967568f0]  compression: 5
FFENC003: [flac @ 000000a5967568f0]  lpc type: Levinson-Durbin recursion with Welch window
FFENC003: [flac @ 000000a5967568f0]  prediction order: 1, 8
FFENC003: [flac @ 000000a5967568f0]  order method: estimate
FFENC003: [flac @ 000000a5967568f0]  partition order: 0, 8
FFENC003: [flac @ 000000a5967568f0]  block size: 4608
FFENC003: [flac @ 000000a5967568f0]  lpc precision: 15
FFENC004: [flac @ 000000a597cc2010] Warning: not compiled with thread support, using thread emulation
FFENC004: [flac @ 000000a597cc2010]  compression: 5
FFENC004: [flac @ 000000a597cc2010]  lpc type: Levinson-Durbin recursion with Welch window
FFENC004: [flac @ 000000a597cc2010]  prediction order: 1, 8
FFENC004: [flac @ 000000a597cc2010]  order method: estimate
FFENC004: [flac @ 000000a597cc2010]  partition order: 0, 8
FFENC004: [flac @ 000000a597cc2010]  block size: 4608
FFENC004: [flac @ 000000a597cc2010]  lpc precision: 15
THDSF: [truehd @ 000000a597946810] Warning: not compiled with thread support, using thread emulation
THDSF: [truehd @ 000000a59844c030] Warning: not compiled with thread support, using thread emulation
001003:0020 DEBUG: Code 3221225628 at (pAf+j}{^F-tOO.=<&,<PDaO_:213131732
001003:0020 DEBUG: Code 3221225628 at cl.v|7^3WFIIIsIn:29393953
Link to the full log (in 2 parts, because 809KB):
http://pastebin.com/pi0PnN5g
http://pastebin.com/jE1jYZ92
angelgraves13
Re: The source file '/BDMV/STREAM/00017.m2ts' is ...
Post by angelgraves13 »
Increase retry count in settings and try again. Probably a bad disc.
yorgo
Post by yorgo »
Also, see here for further suggestions and recommendations:
http://www.makemkv.com/forum2/viewtopic.php?f=8&t=15055
rickyhorror
angelgraves13 wrote:Increase retry count in settings and try again. Probably a bad disc.
Not a bad disc, everything plays on the disc just fine on my blu ray players.
yorgo
Post by yorgo »
It may very well be a bad disc; recommend again to read here: http://www.makemkv.com/forum2/viewtopic.php?f=8&t=15055
"The second thing to remember is that just because a disc can be played successfully in a standalone disc player, it does NOT mean that it can be ripped. Standalone disc players will skip over problematic areas on a disc while MakeMKV needs all information on the disc/track to create an .mkv."
