X-Men Apocalypse: no FUTs are created
bulligt333
#1 Post by bulligt333 » Thu Sep 22, 2016 4:45 pm
I was trying to create mkv.file from X-Men Apocalypse 00800.mpls with 1.10.2
After reading content errormessage poped up
BD+ Code has been progressed, but no FUTs has been created. This could force errors...
BD+ Code wurde bearbeitet, aber es wurden keine FUTs erstellt. Dies kann zu Fehlern führen.
After creating mkv.-file massive compression artifacts are visible.
Any reports?
BR gt
Re: X-Men Apocalypse: no FUTs are created
#2 Post by Woodstock » Thu Sep 22, 2016 7:56 pm
Did you click on the link that was there when you got the NO FUTs message, to report the new BD+ to Mike?
If not, there should have been a .tgz file created in your MakeMKV data directory that needs to be sent to svq@makemkv.com .
Additional details here: /svq/
bulligt333
#3 Post by bulligt333 » Fri Sep 23, 2016 5:51 am
Hi...
unfortunately there was no link to report to mike.. :-(
And I'm not been able to upload the pic due to "Sorry, the board attachment quota has been reached."
Sereby
#4 Post by Sereby » Fri Sep 23, 2016 11:10 am
i have exactly the same problem and i've sent the dump file to the email address
#5 Post by Woodstock » Fri Sep 23, 2016 1:29 pm
Pictures don't help. As explained in the link, we know what happens when it BD+ happens.
For future reference, your MakeMKV data directory (Preferences->General) should have a copy of the file that can be sent after the fact.
Thanks, Sereby, for sending the file.
JayPy
#6 Post by JayPy » Sat Sep 24, 2016 2:38 pm
The german version of "X-Men: Apocalypse" makes the same problem. I have sent in the .tgz-file ;)
jamesryan
#7 Post by jamesryan » Sat Sep 24, 2016 2:55 pm
same Problem, german 2D and 3D .
Fisk123
#8 Post by Fisk123 » Tue Sep 27, 2016 12:38 pm
Same Problem here, also a german 2D Blu-ray. - Send the file.
horkonpon
#9 Post by horkonpon » Tue Sep 27, 2016 8:06 pm
I have the same problem with the spanish version of this BR
I can't send the TGZ file generated by MakeMKV. I have tried with Yahoo Mail and Gmail and both block the TGZ file because of a (false) virus.
How can I send to you the TGZ file?
Thanks in advance
Best regards
Alberto
#10 Post by Woodstock » Wed Sep 28, 2016 12:12 am
At this point, Mike should have enough to make the SVQ file. However, if you have somewhere that you can upload it to temporarily, and send Mike a download link at the same address, that works too.
horkonpon
#11 Post by horkonpon » Wed Sep 28, 2016 2:22 pm
Woodstock wrote:At this point, Mike should have enough to make the SVQ file. However, if you have somewhere that you can upload it to temporarily, and send Mike a download link at the same address, that works too.
Ok, I'll try it
horkonpon
#12 Post by horkonpon » Thu Sep 29, 2016 6:21 pm
Ok, I'll try it
And finally I do it. I have sent the link :D
Thanks for your job
Alberto
Lahiri
#13 Post by Lahiri » Sun Oct 02, 2016 6:14 am
Hi All
I've got the same problem with trying to convert the X-Men Apocalypse Blu-ray (Region B) with "no FUTs are created", I have no doubt Mike is onto this issue. I have not found another video converter that is so well supported and also a one that has such a great open forum where users of this software can get great help and support.
Thanks allhttp://www.makemkv.com/forum2/postin ... 1649cae49#
JayPy
#14 Post by JayPy » Sun Oct 02, 2016 3:15 pm
Now the german version works fine. Thanx a lot! ;)
cad004
#15 Post by cad004 » Wed Oct 05, 2016 3:54 pm
Anyone having any luck with the American version?
