Get the Gringo
wessongroup
Get the Gringo
#1 Post by wessongroup » Fri Sep 23, 2016 3:14 am
First one I've not been able to get to "rip" out of over 1,600 disks
"Processing BD+ code using generic SVQ from builtin/00000.svq"
"BD+ code processed but no FUTs were obtained, errors may follow"
Have tried the suggestions, cleaning and changing sample rate ... no go
yorgo
Re: Get the Gringo
#2 Post by yorgo » Fri Sep 23, 2016 11:23 am
/svq/
"Since MakeMKV doesn't contain any BD+ keys it requires either generic or disc-specific SVQ file to process BD+ protected disc. If no disc-specific SVQ is available or BD+ version is too new for a generic svq, and "BD+ dump directory" is set in preferences then program will create a "BD+ dump file". We will produce and make available for download disc-specific SVQ files from all dump files sent to svq@makemkv.com . Sending us a dump file will help to analyze new versions of BD+ protection and expand the generic svq support.
Usage
Starting from version 1.5.8 MakeMKV downloads all required SVQ files automatically - all discs that require disc-specific SVQ should work without any additional steps. Please see our forum for more details."
