X-Men Apocalypse: no FUTs are created
bulligt333
Post by bulligt333 »
I was trying to create mkv.file from X-Men Apocalypse 00800.mpls with 1.10.2
After reading content errormessage poped up
BD+ Code has been progressed, but no FUTs has been created. This could force errors...
BD+ Code wurde bearbeitet, aber es wurden keine FUTs erstellt. Dies kann zu Fehlern führen.
After creating mkv.-file massive compression artifacts are visible.
Any reports?
BR gt
Re: X-Men Apocalypse: no FUTs are created
Did you click on the link that was there when you got the NO FUTs message, to report the new BD+ to Mike?
If not, there should have been a .tgz file created in your MakeMKV data directory that needs to be sent to svq@makemkv.com .
Additional details here: /svq/
bulligt333
Hi...
unfortunately there was no link to report to mike.. :-(
And I'm not been able to upload the pic due to "Sorry, the board attachment quota has been reached."
Sereby
Post by Sereby »
i have exactly the same problem and i've sent the dump file to the email address
Pictures don't help. As explained in the link, we know what happens when it BD+ happens.
For future reference, your MakeMKV data directory (Preferences->General) should have a copy of the file that can be sent after the fact.
Thanks, Sereby, for sending the file.
JayPy
Post by JayPy »
The german version of "X-Men: Apocalypse" makes the same problem. I have sent in the .tgz-file ;)
jamesryan
Post by jamesryan »
same Problem, german 2D and 3D .
Fisk123
Post by Fisk123 »
Same Problem here, also a german 2D Blu-ray. - Send the file.
horkonpon
Post by horkonpon »
I have the same problem with the spanish version of this BR
I can't send the TGZ file generated by MakeMKV. I have tried with Yahoo Mail and Gmail and both block the TGZ file because of a (false) virus.
How can I send to you the TGZ file?
Thanks in advance
Best regards
Alberto
At this point, Mike should have enough to make the SVQ file. However, if you have somewhere that you can upload it to temporarily, and send Mike a download link at the same address, that works too.
horkonpon
Post by horkonpon »
Woodstock wrote:At this point, Mike should have enough to make the SVQ file. However, if you have somewhere that you can upload it to temporarily, and send Mike a download link at the same address, that works too.
Ok, I'll try it
horkonpon
Post by horkonpon »
Ok, I'll try it
And finally I do it. I have sent the link :D
Thanks for your job
Alberto
Lahiri
Post by Lahiri »
Hi All
I've got the same problem with trying to convert the X-Men Apocalypse Blu-ray (Region B) with "no FUTs are created", I have no doubt Mike is onto this issue. I have not found another video converter that is so well supported and also a one that has such a great open forum where users of this software can get great help and support.
Thanks allhttp://www.makemkv.com/forum2/postin ... 1649cae49#
JayPy
Post by JayPy »
Now the german version works fine. Thanx a lot! ;)
cad004
Post by cad004 »
Anyone having any luck with the American version?
