UPDATE: New BD+ as found in avatar
Tommye1078
Re: UPDATE: New BD+ as found in avatar
#31 Post by Tommye1078 » Mon May 03, 2010 12:23 am
Hey guys
I'm a idiot. I was trying to point the directory at the SVQ file and not a created SVQ directory folder. Sorry for the wasted posts.
setarip_old
#32 Post by setarip_old » Mon May 03, 2010 12:36 am
No harm, no foul - Congratulations ;>}
pippit2
#33 Post by pippit2 » Mon May 03, 2010 10:34 am
can u help me i am new at this i dont know how to set up makemkv prefences up like what to put in aacs and bd+ thank you pippit2
indica
#34 Post by indica » Tue May 04, 2010 6:27 am
Ive tried to mkv the entire disc and use a couple of different players and I cannot get the language translation to appear when the scientists in avatar speak the alien language. Does anyone else have this issue or does MKV have a solution?
Thank you
NomadCF
#35 Post by NomadCF » Tue May 04, 2010 11:51 am
Did you convert the subtitles or are they still in there still original PGS ?
indica
#36 Post by indica » Tue May 04, 2010 4:30 pm
I just used mkv and converted the entire disc subtitles as well. I cant get ANY subtitles to show so I must be doing something wrong? This is the first disc I have ever had this problem with.
Tommye1078
#37 Post by Tommye1078 » Wed May 05, 2010 2:19 am
^ +1
I had the same problem. Couldn't get the subtitles to display. I found a .srt file with the right timing and am using that. If you figure out how to get the subtitles form the avatar Blu Ray to work I would love to hear how you did it.
skittle
#38 Post by skittle » Wed May 05, 2010 2:48 am
Your player needs to support PGS subtitles in MKV. Not many do (yet).
Either use the premade SRT, or convert the PGS to SRT/ASS/SSA, or get a player that supports PGS in MKV.
indica
#39 Post by indica » Wed May 05, 2010 3:10 am
OK I see I was reading about that but I wasnt sure and wanted to eliminate that it could be the mkv rip.
Thank you.
Muzer
#40 Post by Muzer » Wed May 05, 2010 4:17 pm
I think you select the folder itself, not the actual sqv file - the intention being that if you need more (eg disc-specific) sqvs in the future you can put them all in one place and don't have to point it to each one individually.
mnfish
#41 Post by mnfish » Wed May 05, 2010 8:26 pm
OK..So I'm totally lost. How do you save the avatar link to a file in the MakeMKV Folder? I've downloaded the 1.5.5 version. It won't let me save that link in a file. It just asks what program you want to open it with? What am I missing?
mnfish
#42 Post by mnfish » Fri May 07, 2010 1:31 am
Anyone??
benchmarkjoe
#43 Post by benchmarkjoe » Fri May 07, 2010 1:56 am
Thanks you for your hardwork. Finally I did rip the Avatar.
JohnWB
#44 Post by JohnWB » Sat May 08, 2010 1:00 pm
Well I have been tring various things but I keep getting
MakeMKV v1.5.5 beta win(x86-release) started
I am using XP Pro sp3
I made a directory called MakeMKV FilesSVQ & placed the avatar.svq file in there & pointed the program to it but no difference.
The iso file is called avatar.iso
Is there anything else that I can do please
ds2249
#45 Post by ds2249 » Sat May 08, 2010 2:29 pm
JohnWB wrote:Well I have been tring various things but I keep getting
MakeMKV can only get the decryption keys from a real disc. You can not use an ISO file created by some other tool. Please try again with a physical disc.
