Mac OS Sierra broke functionality?
user333
Post by user333 »
Hi there,
I noticed that upon the new update / upgrade to Sierra, my blu-rays are no longer archiving correctly; they are failing with errors. To double-check this, I popped in a blu-ray of mine I had archived just last week (that worked flawlessly), and it failed.
Upon the error, I installed the newest version of MakeMkv, and also the newest "directaspi" driver (or whatever it is) to ensure I was up to date -- same issues.
Anyway, either it's an OS problem, or my drive has suddenly gone bad.
Any suggestions are appreciated -- and thank you!
Here's the info from my last attempted disc, on my Blade Runner: The Final Cut blu-ray -- which did go flawlessly just mere days ago:
MakeMKV v1.10.2 darwin(x86-release) started
Optical drive "BD-RE HL-DT-ST BD-RE WH16NS40 1.00d" opened in OS access mode.
Title #00015.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00001.mpls was added as title #0
Title #00001.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00055.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00065.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/Drobo/zz_movies_and_tv/blu_temp
Hash check failed for file 00047.m2ts at offset 436070400, file is corrupt.
Hash check failed for file 00047.m2ts at offset 767944704, file is corrupt.
Error 'Scsi error - STATUS_05' occurred while reading '/BDMV/STREAM/00047.m2ts' at offset '1041235968'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '1041235968'
Failed to save title 0 to file /Volumes/Drobo/zz_movies_and_tv/blu_temp/title00.mkv
0 titles saved, 1 failed
user333
Re: Mac OS Sierra broke functionality?
Post by user333 »
As an update, here is with debug code enabled...
Debug logging enabled, log will be saved as /Users/john/MakeMKV_log.txt
DEBUG: Code 0 at }ol:1|,X4D4?Aa:121262164
DEBUG: Code 0 at zr.U!^y_P0Zw_LMC:213136148
Hash check failed for file 00047.m2ts at offset 50718720, file is corrupt.
Hash check failed for file 00047.m2ts at offset 576251904, file is corrupt.
Hash check failed for file 00047.m2ts at offset 713287680, file is corrupt.
DEBUG: Code 0 at z:XU`$c@Jl!p?^EYch+6:121262647
The source file '/BDMV/STREAM/00047.m2ts' is corrupt or invalid at offset 724113408, attempting to work around
Hash check failed for file 00047.m2ts at offset 724297728, file is corrupt.
Hash check failed for file 00047.m2ts at offset 1773201408, file is corrupt.
Too many hash check errors in file 00047.m2ts.
The source file '/BDMV/STREAM/00047.m2ts' is corrupt or invalid at offset 3613255680, attempting to work around
Error 'Scsi error - STATUS_05' occurred while reading '/BDMV/STREAM/00047.m2ts' at offset '5097259008'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '5097259008'
DEBUG: Code 1073741829 at l.=[)p[_HFpS#)=V;6:121262969
DEBUG: Code 83886085 at l.=[)p[_HFpS#)=V;6:121262969
DEBUG: Code 0 at Uqj@95l~5sd0]0 U<lCP:121263291
DEBUG: Code 0 at z:XU`$c@Jl!p?^EYch+6:121262302
DEBUG: Code 0 at Uqj@95l~5sd0]0 U<lCP:213130812
DEBUG: Code 2488896 at Uqj@95l~5sd0]0 U<lCP:29393286
DEBUG: Code 0 at K}wjAYQ,p'<kFY]]d6(,W:29398967
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
DEBUG: Code 2281701379 at z^_Ud6tO_w^chvBz:213134676
Mike will have to decode the debug codes, so we'll have to wait for him. You might want to pack up the files requested in the FAQ in my signature and send them to support@makemkv.com to push the process forward a bit.
Sierra isn't "supposed" to break things like this, but when has Apple missed an opportunity to mess with people? :)
user333
Post by user333 »
Woodstock wrote:Mike will have to decode the debug codes, so we'll have to wait for him. You might want to pack up the files requested in the FAQ in my signature and send them to support@makemkv.com to push the process forward a bit.
Haha, that last line made me chuckle aloud...they definitely seem to 'break' things more regularly in their updates than Microsoft. ;)
I will look at your FAQ now and submit the material -- thank you!
bassanoclapper
Post by bassanoclapper »
Is anyone else having problems on Sierra?
Have held off from upgrading so far and don't want to break MakeMKV functionality
user333
Post by user333 »
bassanoclapper wrote:Is anyone else having problems on Sierra?
So as a follow-up to the issue I have been having in Sierra, I tried my PC from the other room and used the same external blu-ray drive -- and it worked flawlessly. From this, I now know it is not the drive itself -- it is the Sierra OS. I am not sure if this will happen with everyone, but it most certainly IS happening on both of my macs (macbook pro and macbook air) that I've updated.
As another interesting point, some of my external drives that I plug into my macs NEVER stop reading, even when not in use. This use to be attributed to a flaw in Spotlight when reading exFAT drives in El Capitan, but could be fixed by excluding the external drive from Spotlight. Now it seems that this persistent reading of the drive cannot be stopped, which has been burning out my drive & slowing data transfers to a crawl.
So, as a solution for now...I would hold off on Sierra. I am going to attempt to use a Time Machine restore on my Macbook Pro, and keep Sierra on my Air -- I am 'assuming' that Apple will fix these issues with time, and then once it works on the Air, I will update the other as well.
Hope this helps some of you out, whether in diagnosing or deciding on upgrading!
bassanoclapper
user333 wrote: As another interesting point, some of my external drives that I plug into my macs NEVER stop reading, even when not in use. This use to be attributed to a flaw in Spotlight when reading exFAT drives in El Capitan, but could be fixed by excluding the external drive from Spotlight. Now it seems that this persistent reading of the drive cannot be stopped, which has been burning out my drive & slowing data transfers to a crawl
Thanks for the update
It might be worthwhile feeding that back to Apple as a bug
http://www.apple.com/feedback/macosx.html
user333
Post by user333 »
That's a great idea...I'm going to do that now. :)
neverman
Post by neverman »
Yes, same errors.
bassanoclapper
I made the leap and upgraded and have noticed no issues so far. Perhaps it's more about individual set-up rather than a problem with Sierra
sfvideoguy
Post by sfvideoguy »
I don't know whether to upgrade or not. Can the developer please comment as to whether the newest version of your software works with OS X Sierra? Thank you.
user333
Post by user333 »
sfvideoguy wrote:I don't know whether to upgrade or not. Can the developer please comment as to whether the newest version of your software works with OS X Sierra? Thank you.
I am waiting on confirmation on this as well...I rolled back to the previous OS in the meantime (I'm the OP of this thread).
Lovely Rita
Post by Lovely Rita »
No issues with Sierra/MakeMKV.
Registered User :wink:
Buy MakeMKV
philb1701
Post by philb1701 »
I'm running into the same problem but the software usually manages to work through it.
I'm having a particular problem with RED 2 where it simply stops at a certain point.
Film-fan
Post by Film-fan »
philb1701 wrote: Mon Nov 21, 2016 12:31 am I'm running into the same problem but the software usually manages to work through it.
Ah, RED 2, a problem disk! Load up VLC and open the disk in VLC (like you're going to play the DVD). Pause it.
Then start MakeMKV, and you should see things go well. I had received odd messages about re-flashing my DVD drive with stuff from tbd.rmc1.org, which I can't do very well. I'd seen an answer in a post elsewhere that VLC knows how to "open" a DVD -- unlock the hardware, as it were -- and then other code can access the disk. It has worked very nicely for me, at least.
