I am trying to back up my copy of Saved by the Bell. When I run the disk it says three titles saved 3 failed. The disc has 8 episodes on it. Below is the log before clicking MakeMKV. I tried to attach the debug log and the .IFO files but it said the board attachment quota has been reached. How can I get the disc to work right?
"MakeMKV v1.10.2 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\The Escobars/MakeMKV_log.txt
Title #1 was added (1 cell(s), 0:22:15)
Title #2 was added (1 cell(s), 0:22:15)
Title #3 was added (1 cell(s), 0:22:15)
Title #4 was added (1 cell(s), 0:22:15)
Title #5 was added (1 cell(s), 0:22:15)
Title #6 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 was added (1 cell(s), 0:22:14)
Title #9 was added (1 cell(s), 0:23:19)
Title #10 was added (2 cell(s), 0:22:22)
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '32768'
DEBUG: Code 100864000 at 0*u53V?r+$wd$Pq.aI:121262969
DEBUG: Code 1 at dwTCm}Gg$DE/1iF':213130789
DEBUG: Code 0 at OCfXDt"Li2W<fr :121271180
DEBUG: Code 0 at Oi!4%N-q@VcJ#P:121266580
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '2048'
DEBUG: Code 100864256 at 0*u53V?r+$wd$Pq.aI:121262969
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '2048'
Operation successfully completed"
Saved by the Bell Failed to Save
Re: Saved by the Bell Failed to Save
No need for the IFO files, this says what needs to be said:
Your drive is having problems reading part of the disk. First thing to try is cleaning it with a damp, soft cloth, preferably cotton or microfiber. Even if it "looks clean and perfect", your drive thinks otherwise.Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '2048'
TheEscoMo
This was a brand new disc from a sealed box. It plays in the media player both on the computer and the playstation. Disc 2 of the set had no issues. I tried cleaning it but have not had success making the MKVs. I tried to make an iso of the disc and that did not work either. Any other suggestions? Thanks!
