Error reading DVD Ride Along
Nikster
Post by Nikster » Mon Sep 19, 2016 7:28 pm
Here is another ERROR. PASTED ALL THE INFO
THANK YOU FOR YOUR HELP.
Title #3 was added (1 cell(s), 0:02:59)
Title #4 was added (1 cell(s), 0:03:19)
Title #5 has length of 26 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #6 has length of 14 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #7 was added (21 cell(s), 1:39:21)
Title #8 was added (7 cell(s), 0:05:01)
Title #9 was added (1 cell(s), 0:11:52)
Saving 1 titles into directory C:/Users/nmitelligmail.com/Videos/VIDEO NEW MKV 1
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/VIDEO_TS/VTS_06_1.VOB' at offset '3846473728'
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom0' at offset '3846473728'
DEBUG: Code 3221225861 at 0*u53V?r+$wd$Pq.aI:121262969
DEBUG: Code 100927744 at 0*u53V?r+$wd$Pq.aI:121262969
DEBUG: Code 0 at 8=h{tZTtt133Ig!gb;mX:121263291
DEBUG: Code 0 at DxIJT?6Nhc_=P66"\8e:121261750
DEBUG: Code 0 at 8=h{tZTtt133Ig!gb;mX:213130812
DEBUG: Code 1878161 at 8=h{tZTtt133Ig!gb;mX:29393286
DEBUG: Code 0 at T:}L'Aj<w&w(~v+!IEKR(:29398967
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 2 to file C:/Users/nmitelligmail.com/Videos/VIDEO NEW MKV 1/RIDE_ALONG.mkv
0 titles saved, 1 failed
Nikster :D
Re: Error reading DVD Ride Along
Post by Woodstock » Mon Sep 19, 2016 8:07 pm
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/VIDEO_TS/VTS_24_1.VOB' at offset '16623616'
Your drive would seem to be failing, if you get this EXACT SAME ERROR on 4 different disks.
Nikster
Post by Nikster » Mon Sep 19, 2016 8:31 pm
I wasn't trying to scatter. These discs are the only discs out of 50 i just did.
Maybe i should of said that.
I have done 300 discs and these movies within the 50 I did today, THESE MOVIES have these errors.
Nikster :D
