Error reading DVD MAN UP!
Nikster
Post by Nikster » Mon Sep 19, 2016 7:34 pm
Another DVD ERROR
Thank you for the help.
Title #1 has length of 42 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #3 was added (5 cell(s), 0:08:41)
Title #8 has length of 6 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #10 was added (1 cell(s), 0:06:22)
Title #12 was added (1 cell(s), 0:04:06)
Title #13 was added (1 cell(s), 0:40:30)
Title #14 has length of 5 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #16 has length of 5 seconds which is less than minimum title length of 175 seconds and was therefore skipped
DEBUG: Code 10551306 at SJ*@jg/<lv-`O[VY:213142128
DEBUG: Code 0 at SJ*@jg/<lv-`O[VY:213143301
DEBUG: Code 0 at %`~=(gEentO3T:$#8S:29394229
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Cells 18-18 were removed from title end
Title #23 was added (16 cell(s), 1:28:24)
Title #25 was added (16 cell(s), 1:28:24)
Title #27 was added (16 cell(s), 1:28:24)
Title #31 was added (16 cell(s), 1:28:24)
Title #35 was added (16 cell(s), 1:28:24)
Title #47 was added (22 cell(s), 1:32:13)
Title 1 in VTS 14 is equal to title 1 and was skipped
Saving 1 titles into directory C:/Users/nmitelligmail.com/Videos/VIDEO NEW MKV 1
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/VIDEO_TS/VTS_24_1.VOB' at offset '16623616'
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom0' at offset '16623616'
DEBUG: Code 3221225861 at 0*u53V?r+$wd$Pq.aI:121262969
DEBUG: Code 100927744 at 0*u53V?r+$wd$Pq.aI:121262969
DEBUG: Code 0 at 8=h{tZTtt133Ig!gb;mX:121263291
DEBUG: Code 0 at DxIJT?6Nhc_=P66"\8e:121261750
DEBUG: Code 0 at 8=h{tZTtt133Ig!gb;mX:213130812
DEBUG: Code 8117 at 8=h{tZTtt133Ig!gb;mX:29393286
DEBUG: Code 0 at T:}L'Aj<w&w(~v+!IEKR(:29398967
Failed to save title 5 to file C:/Users/nmitelligmail.com/Videos/VIDEO NEW MKV 1/_MAN_UP.mkv
0 titles saved, 1 failed
Nikster :D
Re: Error reading DVD MAN UP!
Post by Woodstock » Mon Sep 19, 2016 8:08 pm
Try it with a working drive - this one seems to be failing.
