I copied everything for this DVD. I did clean the DVD as well.
Is there a solution THAT I NEED TO DO?
Thank you for the help!
MakeMKV v1.10.2 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\nmitelligmail.com/MakeMKV_log.txt
Title #2 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #3 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #4 has length of 22 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #5 was added (5 cell(s), 0:08:33)
Title #8 has length of 9 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #9 has length of 22 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #10 has length of 10 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #11 has length of 100 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #12 has length of 62 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #13 has length of 134 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #14 has length of 100 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #15 has length of 62 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #16 has length of 134 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #17 has length of 142 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #19 has length of 142 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #21 has length of 152 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #22 has length of 5 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #24 has length of 5 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #27 was added (21 cell(s), 1:42:46)
Title #28 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #29 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #30 was added (20 cell(s), 1:37:43)
Title #31 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #32 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #34 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #35 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #36 was added (23 cell(s), 1:52:35)
Title #37 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #38 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
DEBUG: Code 10551300 at SJ*@jg/<lv-`O[VY:213142128
DEBUG: Code 0 at SJ*@jg/<lv-`O[VY:213143301
DEBUG: Code 0 at %`~=(gEentO3T:$#8S:29394229
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Cells 18-18 were removed from title end
Title #39 was added (16 cell(s), 1:49:46)
Title #40 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #41 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #42 was added (16 cell(s), 1:49:46)
Title #43 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #44 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #45 was added (23 cell(s), 1:52:35)
Title #46 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #47 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #48 was added (16 cell(s), 1:49:46)
Title #49 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #50 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #52 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #53 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #55 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #56 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #57 was added (16 cell(s), 1:49:46)
Title #58 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #59 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #61 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #62 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #63 was added (16 cell(s), 1:49:46)
Title #64 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #65 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #66 was added (16 cell(s), 1:49:46)
Title #67 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #68 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #69 was added (18 cell(s), 1:21:59)
Title #70 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #71 has length of 1 seconds which is less than minimum title length of 175 seconds and was therefore skipped
Title #72 was added (22 cell(s), 1:52:10)
Title 1 in VTS 16 is equal to title 1 and was skipped
Title 1 in VTS 17 is equal to title 1 and was skipped
Saving 1 titles into directory C:/Users/nmitelligmail.com/Videos/VIDEO NEW MKV 1
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/VIDEO_TS/VTS_16_1.VOB' at offset '24274944'
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom0' at offset '24274944'
DEBUG: Code 3221225861 at 0*u53V?r+$wd$Pq.aI:121262969
DEBUG: Code 100927744 at 0*u53V?r+$wd$Pq.aI:121262969
DEBUG: Code 0 at 8=h{tZTtt133Ig!gb;mX:121263291
DEBUG: Code 0 at DxIJT?6Nhc_=P66"\8e:121261750
DEBUG: Code 0 at 8=h{tZTtt133Ig!gb;mX:213130812
DEBUG: Code 11853 at 8=h{tZTtt133Ig!gb;mX:29393286
DEBUG: Code 0 at T:}L'Aj<w&w(~v+!IEKR(:29398967
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 3 to file C:/Users/nmitelligmail.com/Videos/VIDEO NEW MKV 1/_DRAFT_DAY.mkv
0 titles saved, 1 failed
DRAFT DAY ERROR READING
Re: DRAFT DAY ERROR READING
No need to scatter the same question all over the forum, when you have a failing drive.Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/VIDEO_TS/VTS_16_1.VOB' at offset '24274944'
