Criterion "It's A Mad, Mad, Mad, Mad World" (both Blu-Rays)
jpidgeon
Post by jpidgeon »
I've restarted the computer.
I've uploaded the latest version.
For whatever reason, I can't get MakeMKV to recognize the Blu-Ray discs for the Criterion "It's A Mad, Mad, Mad, Mad World". I pop the disc into the drive, it thinks for a little bit, then states, "No Disc."
DVDs are working just fine - I haven't tried another Blu-Ray since this occurred, but it's been ripping them just fine for months with very few problems (and this specific issue hasn't happened until now).
Has anyone else run into this issue with this (or another) title?
yorgo
Re: Criterion "It's A Mad, Mad, Mad, Mad World" (both Blu-Ra
Post by yorgo »
I've successfully ripped this disc, without the issue you've experienced. I've had "no disc" crop up infrequently but after the disc is ejected, I reinsert and continue on with no further problems. If other blu-ray discs work (I assume you've tried others since this one failed) and this is the only set with problems, try cleaning the discs carefully and thoroughly. Can you try different copies?
