Pushing Daisies: Season 1
gabeen
#1 Post by gabeen » Sun Aug 07, 2016 3:01 pm
Pushing Daisies: Season 1 have all the episodes merged together into 1 episode in MakeMKV.
MakeMKV maps all the episodes together in the Segment map. All the episodes are seperate files on the actual blu-ray disc.
I have backed up the discs and removed the *.m2ts files and uploaded it here:
https://drive.google.com/open?id=0BypG0 ... 0NfV2ZSWTg
PUSHING_DAISIES_S1_BD01_DIM1
Source file name: 00004.mpls
Duration: 2:06:08
Chapters count: 23
Segment count: 3
Segment map: 4,11,12
File name: title00.mkv
PUSHING_DAISIES_S1_BD01_DIM2
Duration: 2:06:11
Chapters count: 24
Segment count: 3
PUSHING_DAISIES_S1_BD01_DIM3
Duration: 2:08:14
Chapters count: 24
Segment count: 3
Segment map: 4,62,63
gabeen
Re: Pushing Daisies: Season 1
#2 Post by gabeen » Fri Sep 16, 2016 6:27 pm
Update: Just tried the new build, MakeMKV v1.10.2 (11.9.2016 ) - and the issue still occurs.
Could you fix this please? You fixed it for Weeds Season 1.
prophecy0
#3 Post by prophecy0 » Sun Sep 18, 2016 5:15 am
I would like to second this request please.
jinx100
#4 Post by jinx100 » Sun Sep 18, 2016 1:41 pm
You've asked the same question several times. MakeMKV only allows copying of the original disc as it was originally authored. You need to use other applications to edit or reformat the media. Handbrake (and likely other programs) can select and separate the groups of chapters for each episode. I wish MakeMKV would brew my coffee but it does not.
Lovely Rita
#5 Post by Lovely Rita » Sun Sep 18, 2016 3:35 pm
jinx100 wrote: Handbrake (and likely other programs) can select and separate the groups of chapters for each episode.
Yes, As mentioned to him in one of his other posts. Fringe Season 1
Registered User :wink:
Buy MakeMKV
jinx100
#6 Post by jinx100 » Sun Sep 18, 2016 5:22 pm
Sorry Rita, you deserve credit for first suggesting Handbrake. A quick Google search also gives MKV toolbox, ffmpeg and command line Handbrake as solutions. I was just piqued that the original poster gave five error reports for his misunderstanding of MakeMKV.
