Ferris Buellers Day Off
Nikster
Post by Nikster »
I have run into this error on a couple of dvd's.
I have pasted the error logs.
is THERE A WAY TO FIX THIS?
Thanks for any info.
Saving 1 titles into directory C:/Users/nmitelligmail.com/Videos/VIDEO NEW MKV 1/FERRIS_BUELLER
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '1699313664'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '1699313664'
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '1701705728'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '1701705728'
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '1710618624'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '1710618624'
DEBUG: Code 3221225628 at 0*u53V?r+$wd$Pq.aI:121262969
DEBUG: Code 100864256 at 0*u53V?r+$wd$Pq.aI:121262969
DEBUG: Code 0 at 8=h{tZTtt133Ig!gb;mX:121263291
DEBUG: Code 0 at DxIJT?6Nhc_=P66"\8e:121261750
DEBUG: Code 0 at 8=h{tZTtt133Ig!gb;mX:213130812
DEBUG: Code 835263 at 8=h{tZTtt133Ig!gb;mX:29393286
DEBUG: Code 0 at T:}L'Aj<w&w(~v+!IEKR(:29398967
Failed to save title 0 to file C:/Users/nmitelligmail.com/Videos/VIDEO NEW MKV 1/FERRIS_BUELLER/title00.mkv
0 titles saved, 1 failed
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '1914992640'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '1914992640'
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '1917057024'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '1917057024'
DEBUG: Code 936063 at 8=h{tZTtt133Ig!gb;mX:29393286
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Nikster :D
Re: Ferris Buellers Day Off
Your drive says it can't read parts of the disk. The first two errors encountered were eventually figured out with retries, but then there was an error that retries didn't "fix".
First thing to try is cleaning the disk, even if it "looks clean and perfect and works when I play it in my DVD player". DVD and BD players will tolerate errors that shut down ripping, and not everything that disturbs a laser beam is visible to the human eye.
Sometimes the disks are actually defective - I have a brand new BD sitting here that looks perfect, has been cleaned twice, and still fails to read on two episodes out of 10. Three different drives think the disk is unformatted... I'm waiting to exchange it for a new copy.
Nikster
Post by Nikster »
Thank you, I will try cleaning the disc and see how it goes.
Nikster :D
