Version 1.10.2 BD 3D not working on med600x3d
cockers
Post by cockers »
After upgrading to 10.2, 3D BD's that are ripped with mvc enabled are not displaying 3D on med600x3d. I'm not sure when this was broken, but it also does not work with 10.1 - it definitely worked prior to that, but not sure which version.
cockers
Re: Version 1.10.2 BD 3D not working on med600x3d
Post by cockers »
My apologies, it is working, I forgot to change the file extension to file.TB.mkv
Mind you, this is easy to forget and would be good if it could be added automatically for 3D movies.
