New Version 1.10.2 Issues
fizban11
Post by fizban11 »
Mike admin,
Since updating to 1.10.2 this past weekend, I have ripped 3 Blu-Rays, all older discs: Harry Potter 1-3. All three discs playback as if framerate is not synching, just a slight stutter.
Nothing else has changed on my PC system and rips prior to the update to 1.10.2 play back just fine via Popcorn Hour VTEN and PLEX Media Server/Client. I suspect a problem of encoding/ripping with MakeMKV 1.10.2. I have a lifetime paid subscription which can be found via my e-mail address on file. Please help.
Has anyone else reported issues with 1.10.2?
jinx100
Re: New Version 1.10.2 Issues
Post by jinx100 »
One advantage of subscribing is that you can easily re-install old versions. http://www.makemkv.com/download/old/
See if 10.1.1 helps.
angelgraves13
Post by angelgraves13 »
It's probably just the usual issue of Media Players not being able to play VC-1 content without a constant frame drop. WD TV Live is the same. It should play fine on PC.
