"A Hologram for the King" correct mpls?
DrDon
#1 Post by DrDon » Tue Aug 09, 2016 4:47 pm
Netflix disc, though it's not marked "rental only" nor "Netfix."
"A Hologram for the King." All of the files show the proper runtime. Anyone know which one's the right one?
Much thanks.
GRUPPR
Re: "A Hologram for the King" correct mpls?
#2 Post by GRUPPR » Tue Aug 09, 2016 9:32 pm
This is the sequence I found on Netflix:
Title information
Name: A Hologram for the King (2016)
Source file name: 00714.mpls
Duration: 1:38:10
Chapters count: 16
Segment count: 15
Segment map: 105,113,114,106,115,104,110,107,108,112,101,102,111,109,103
File name: A_Hologram_for_the_King_(2016)t210.mkv
JohnnySoccer
#3 Post by JohnnySoccer » Tue Aug 09, 2016 11:32 pm
I show the same thing for the Redbox version.
outdoorguy568
#4 Post by outdoorguy568 » Tue Aug 09, 2016 11:46 pm
I got the same MPLS (714) for Red also.
But!...... I'm receiving error for file not saved with hundreds of rows with these errors:
The source file '/BDMV/STREAM/00110.m2ts' is corrupt or invalid at offset 1381472256, attempting to work around
The source file '/BDMV/STREAM/00110.m2ts' is corrupt or invalid at offset 1381478400, attempting to work around
Never had this error before.
taseldor
#5 Post by taseldor » Wed Aug 10, 2016 1:56 am
outdoorguy568 wrote:I got the same MPLS (714) for Red also.
That's probably a physical problem on the disc. If you're lucky it's a speck of something you can wash off. If unlucky, it's a scratch or a nick and you won't be able to rip the file.
outdoorguy568
#6 Post by outdoorguy568 » Wed Aug 10, 2016 3:35 am
Cleaned it well still could not rip it... same errors; btw disk looks perfect. Tried a different program which ripped it to an ISO file then used MakeMKV with no problems converting the ISO to an MKV file.... very odd.
DrDon
#7 Post by DrDon » Wed Aug 10, 2016 1:29 pm
Tremendous thanks!
c1823a
#8 Post by c1823a » Wed Aug 24, 2016 12:17 pm
What did you use to rip to an ISO? I tried MakeMKV with a standard DVD rental and got errors that would not let me copy.
c1823a
#9 Post by c1823a » Mon Sep 12, 2016 12:08 pm
^Bump^
yorgo
#10 Post by yorgo » Tue Sep 13, 2016 1:02 am
What was the error message?
BTW, my general experience has been that, once a disc has been successfully decrypted, if it doesn't rip with MakeMKV, it doesn't rip with any other software (TSMuxer, MKVToolNix). An error, seen or unseen, exists on the disc and the software can't get around it. Trying different drives, however, has been helpful; if it fails in one, it sometimes works in another.
Vilesyde
#11 Post by Vilesyde » Tue Sep 13, 2016 9:29 am
he probably used AnyDVD it will rip to an ISO file.
RonRN18
#12 Post by RonRN18 » Thu Feb 02, 2017 12:00 am
GRUPPR wrote:This is the sequence I found on Netflix:
Title information
Duration: 1:38:10
Chapters count: 16
Segment count: 15
I am curious as to how this information is found in the first place. Is it trial and error or is there a tool for discovering?
thecross
#13 Post by thecross » Thu Feb 09, 2017 3:04 am
Title information
Duration: 1:38:10
Chapters count: 16
Segment count: 15
That is a very good question. I am also interested in how this information was obtained.
EVOXGSR
#14 Post by EVOXGSR » Mon Feb 13, 2017 4:12 am
thecross wrote:
Title information
Duration: 1:38:10
Chapters count: 16
Segment count: 15
Process monitor - Filter by .mpls with PowerDvd
Look for the Playlist with only ReadFile under operation.
The incorrect playlists will have entries under operation of ReadFile and QueryStandardInformationFile
To double check
Process monitor - Filter by .m2ts with PowerDvd
Play the movie x16 and capture the .m2ts sequence
Compare the playlist to the sequence.
