Now you see me 2 correct playlist
gereral1
Re: Now you see me 2 correct playlist
Post by gereral1 » Thu Sep 08, 2016 12:08 pm
gamecaptor wrote:Redbox USA. AnyDVD 8.0.4.0 says:
Java BD protection good playlists: 626
Tried to use Process Monitor 3.2 to verify but it's telling me "blocked by virtual memory" and is spitting out a bunch of different mpls numbers (i.e. it can't seem to read the correct one). This is the first time I've seen this.
Mpls.DLL and m2ts.DLL cause this. Process monitor will not work anymore with memory capture. I'm sure someone will crack this..... Maybe a debugger on these DLLs could reveal the playlist. Memory calls reside on the stack. Breakpoint the memory point at the call of m2ts or mpls.DLL will reveal the playlist. Watch what gets push and popped of the stack before it scrambles the play order. I'm sure those redfox guys do exactly this to figure out screen pass disks. I use to mess with a debugger along time ago on a program I bought to register it without my key.
Zonian
Post by Zonian » Fri Sep 09, 2016 12:28 pm
Several of you posted the same playlist for red version but MKV listed another as the main feature... does this mean this feature of MKV is not reliable?... Yet :P I used to use process monitor but as everyone knows it's no longer working so now I am stumped as to how to find it myself :( Many thanks to those of you on here who are kind enough to post the correct playlist for clueless people like me :) You're awesome!
shingaimav
Post by shingaimav » Fri Sep 09, 2016 3:05 pm
Thank you all for your help.
mr2686
Post by mr2686 » Fri Sep 09, 2016 4:01 pm
Zonian wrote:Several of you posted the same playlist for red version but MKV listed another as the main feature... does this mean this feature of MKV is not reliable?... Yet :P I used to use process monitor but as everyone knows it's no longer working so now I am stumped as to how to find it myself :( Many thanks to those of you on here who are kind enough to post the correct playlist for clueless people like me :) You're awesome!
Yes, as far as MKV for picking out the correct feature when there are several to chose from, it can be unreliable. Always check here first...there are a lot of good people that devote their time to figuring out the right one.
Torrentwin
Post by Torrentwin » Fri Sep 09, 2016 4:21 pm
... please delete ...
yorgo
Post by yorgo » Fri Sep 09, 2016 11:19 pm
It is a work in progress as Mike has stated. I'm sure in time and with enough effort, he'll have it completely nailed down. In the meantime, there is RedFox AnyDVD which works very well; probably what those "good people that devote their time" are using! :wink:
mr2686
Post by mr2686 » Sat Sep 10, 2016 5:42 pm
[quote="yorgo
It is a work in progress as Mike has stated. I'm sure in time and with enough effort, he'll have it completely nailed down. In the meantime, there is RedFox AnyDVD which works very well; probably what those "good people that devote their time" are using! :wink:[/quote]
Those sneaky rascals. LOL
robdek11
Post by robdek11 » Tue Sep 13, 2016 12:32 am
Does anyone have the correct playlist for the Canadian Rental version. MakeMKV is identifying it as 00939 with the following:
Segment map: 510,503,507,509,511,504,506,512,501,502,515,513,514,505,508
Ripped and played back and it is definitely not the correct playlist. Every playlist on the disk starts with the same first 5 segments.
thanks,
Torrentwin
Post by Torrentwin » Tue Sep 13, 2016 4:04 am
@robdek11,
This one should be what you are looking for :-)
Source file name: 00492.mpls
Segment map: 510,503,507,509,511,506,505,504,501,513,515,514,502,512,508
MonsterMaxx
Post by MonsterMaxx » Mon Nov 14, 2016 4:14 pm
is netflix 626 as well?
foxer10
Post by foxer10 » Sun Nov 27, 2016 3:26 am
How do you figure this out? Im sure its not someone having to rip all titles and watch one at a time?
Rabadawg211 wrote:After doing it the hard way. I am also getting 626 as the correct playlist for the US Redbox version of the movie. Segment map for this version should be:
507,508,503,506,513,510,512,505,514,504,511,509,501,502,515
xbmcuser
Post by xbmcuser » Tue Dec 06, 2016 12:54 am
Confirmed Netflix
Name: Now You See Me 2
Source file name: 00626.mpls
Duration: 2:09:13
Chapters count: 16
Segment count: 15
Segment map: 507,508,503,506,513,510,512,505,514,504,511,509,501,502,515
For some reason the new Makemkv Java Obfuscation detection did not pick the correct title. Previous movies it worked fine.
Previously I have posted a 100% free way of doing this in Linux is the following:
http://www.makemkv.com/forum2/viewtopic ... 959#p42657
Reposting Here:
Researching this it seems the best/fastest way to find the correct segment map is to first backup the entire disc, which should be of normal size. Then knowing you need to work with a certain subset of segments your job is to now figure out their correct order, which the superset can be found here: BDMV/STREAM. You should be able to find each segment's starting point and length by referencing the movie.
It is somewhat tedious but using simple time math you can figure out the correct mapping faster than real time of the movie.
bart1964
Post by bart1964 » Tue Dec 27, 2016 2:35 pm
Hey, any help on the proper playlist for the Canadian retail version from Walmart?
Thanks.
Bart
EvilEmpire
Post by EvilEmpire » Sat Jan 14, 2017 1:05 am
Can someone provide the correct playlist for US version sold by Best Buy?
That Netflix copy has diffferent segment map.
Thanks.
adamw
Post by adamw » Sun May 28, 2017 9:06 pm
I'm still trying to figure out which mpls I need for this movie.
Purchase Location: Amazon or Best Buy
Blu-ray, DVD + UltraViolet edition
UPC: 03139825056280
Region 1
MakeMKV says it's 786. However, when I've tried using Process Monitor, it says I should be using 976; but that mpls isn't selectable in MakeMKV.
Any assistance would be greatly appreciated.
