Sherlock-abominable bride. successful rip, unreadable result
Smiske
#1 Post by Smiske » Fri Sep 09, 2016 11:37 am
Sherlock, the abominable bride (blue ray disc), 5051561003288 (region 2)
Successful rip to MKV, but MKV cannot be read by Handbrake: No valid source found
Someone any ideas?
Re: Sherlock-abominable bride. successful rip, unreadable re
#2 Post by Woodstock » Fri Sep 09, 2016 2:27 pm
First question: Can you play the MKV file in VLC from VideoLan.org?
If so, the issue is probably with handbrake. There are a number of things that can cause handbrake to declare a file "invalid", depending upon the version you are using. One of them is audio sources. This will show up in the activity logs, which they WILL need over on handbrake.fr to help you.
Smiske
#3 Post by Smiske » Sat Sep 10, 2016 12:58 pm
Yes, MKV-file is playable in VLC. So the problem is with handbrake :)
I'll go and harass them now while trying to compress my MKV to MP4 using other app.
Thanks for the help!
angelgraves13
#4 Post by angelgraves13 » Sun Sep 25, 2016 4:33 am
Smiske wrote:Sherlock, the abominable bride (blue ray disc), 5051561003288 (region 2)
Someone any ideas?
Possibly an issue with an Atmos stream.
