K2828
Post
by K2828 » Fri Apr 23, 2010 7:12 pm
Hi everyone,
i wantet to make an mkv file of my dvd but i gettin this error:
Calculated BUP offset does not match one in IFO header.
Title #0 was skipped
Here are 2 .ifo files:
(Direkt Link, no wait)
http://rapidshare.com/files/379308427/Desktop.rar
Regards
setarip_old
Post
by setarip_old » Fri Apr 23, 2010 7:37 pm
Hi!
1) What is the title and Region number of your original, commercial DVD?
2) Which is this the result of - Using a ripped copy of the DVD or using your original, commercial DVD as the source for input into MakeMKV?
K2828
Post
by K2828 » Fri Apr 23, 2010 7:49 pm
Its, a home made video that i made with my cam. so i think the dvd has no region code.
This is an ifo file from a dvd that i created,too. From this dvd i made a mkv file with no problems.
http://rapidshare.com/files/379318909/VTS_01_0.rar
The only difference i see is that the first dvd i couldnt rip has a video_rm and video_ts folder and the one i could rip has just a video_ts folder.
K2828
Post
by K2828 » Wed Apr 28, 2010 3:48 pm
Post
by mike admin » Thu Apr 29, 2010 8:37 am
K2828 wrote:Its, a home made video that i made with my cam. so i think the dvd has no region code.
MakeMKV only reads DVD-VIDEO discs. Your camera software creates incompatible discs.
K2828
Post
by K2828 » Sun May 02, 2010 3:27 pm
Is it possible, that i convert them into a compatible .iso file, then mount it with daemon tools and at last convert the video files to .mkv?
If yes, do anyone knows wich application i can use for this?
