The Force Awakens
MitchT
The Force Awakens
Post by MitchT »
Trying to backup The Force Awakens. MakeMKV errors saying files are corrupts and ends up crashing. See image below. I am not sure what the issue is. Disk is clean, works in player. Blu Ray Player is brand new Pioneer BDR-XD05 3.01
https://www.amazon.com/clouddrive/share ... _link_copy
Re: The Force Awakens
The first thing to check, when confronting a large number of errors like this, is how clean the disk is. It is remarkable the number of disks arriving "new, sealed" that seem to have a light haze of chemicals on them that interferes with the blue laser. Sometimes you can see the outline of the suction cups used to load the disks in the packaging, just by tilting the disk a bit.
A clean, damp, soft cloth (cotton or microfiber) should be used to wipe any disk, new or old, that shows errors like this. If the errors go away, you are done.
Sometimes the errors change; we would need to know about that, too.
If you have debug logging turned on, you don't have to send "pictures" of the errors; post the text from the log instead. It's easier than trying to figure out what's written when the screen shot gets resized.
