Can't Read AACS VID from Drive
gourdcaptain
Post by gourdcaptain »
Trying to rip a disc on Arch Linux (64-bit) with 1.10.1. It fails to open on my new archgon MD-3102 BD USB drive (the first thing I did after unpacking the drive) with the following log:
Debug log started at Mon Sep 5 21:31:00 2016 , written by MakeMKV v1.10.1 linux(x64-release)
001005:0000 MakeMKV v1.10.1 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/gourdcaptain/MakeMKV_log.txt
DEBUG: Code 2147483648 at ;TSv{!=P&wF xr3L:121265315
DAFD=PAAAADAAAAEABDQkEGwEBAQ==
001003:0020 DEBUG: Code 0 at CW)IQHg,)J-.X5%fs:213130582
001003:0020 DEBUG: Code 0 at ^5o}/9L):-[JBY;9zH:29395195
001003:0020 DEBUG: Code 0 at ^5o}/9L):-[JBY;9zH:121262647
001003:0020 DEBUG: Code 1 at ^5o}/9L):-[JBY;9zH:121262647
001003:0020 DEBUG: Code 2 at ^5o}/9L):-[JBY;9zH:121262647
001003:0020 DEBUG: Code 3 at ^5o}/9L):-[JBY;9zH:121262647
001003:0020 DEBUG: Code 4 at ^5o}/9L):-[JBY;9zH:121262647
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..0800024C0 to device 'SG:dev_11:0'
DEBUG: Code 0 at CW)IQHg,)J-.X5%fs:213130306
001003:0020 DEBUG: Code 0 at ^5o}/9L):-[JBY;9zH:29396345
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003341:0000 Highest AACS version is v61 , MKB saved as /home/gourdcaptain/.MakeMKV/MKB_v61_BATMAN_V_SUPERMAN_DOJ.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at VU]TXM^]DE#Ahd2&:213132146
001003:0020 DEBUG: Code 0 at VU]TXM^]DE#Ahd2&:29397817
EDIT: My older, slower, and USB 2 drive does work with the same computer. (Except for the tray detection being off until you cycle it and ejects being unreliable, but that's a problem with the drive and age.)
