The Last Witch Hunter - BluRay - Error reading Disc at 75%
dr0pd34d
Post by dr0pd34d »
Hello Guys,
i am trying to read the BluRay mentioned in the title.
I do have a debug log file and the MKB.tgz but the board attachment quota has been reached.
The disc is read fine with and without DVDFab Passkey or AnyDVD HD until at about 75% the disc read errors occur.
The disc was cleaned and looks alright.
Disc Information of AnyDVD HD:
Summary for drive F: (AnyDVD HD 8.0.4.0, BDPHash.bin 16-05-19)
HL-DT-ST BDDVDRW CH10LS20 1.01 4 B007071196A6NG1754
Drive (Hardware) Region: 2
Media is a Blu-ray disc.
Total size: 22822368 sectors (44574 MBytes)
Video Blu-ray label: THE LAST WITCH HUNTER
Media is AACS protected!
AACS MKB version 60
Removed AACS copy protection!
Blu-ray disc is region free!
The link to the Debug Log Download:
http://www.filedropper.com/makemkvlogthewitchhunter
The link to the MKB.tgz:
http://www.filedropper.com/mkbv60thelastwitchhunter
Maybe someone else has an Idea?
Thanks a lot for any help.
yorgo
Re: The Last Witch Hunter - BluRay - Error reading Disc at 7
Post by yorgo »
I'm assuming you meant the error is in ripping the disc because your AnyDVD information states that the encryption has been removed. If you meant that there is a read error while ripping, see here: http://www.makemkv.com/forum2/viewtopic.php?f=8&t=15055
dr0pd34d
Post by dr0pd34d »
yorgo wrote:I'm assuming you meant the error is in ripping the disc because your AnyDVD information states that the encryption has been removed. If you meant that there is a read error while ripping, see here: http://www.makemkv.com/forum2/viewtopic.php?f=8&t=15055
Okay thank you, so even if it is able to play normally in the PS3 for example i should replace the disc and try it again?
Because the error messages in the Log did not look like the ones in the link you posted.
It was something along the line "Host Reading took too long" and "File is corrupt at POINT trying to avoid it
yorgo
Post by yorgo »
Because a disc will play fine on a stand-alone player does not mean it will rip.
Pleas post the exact text you are seeing in MakeMKV.
dr0pd34d
Post by dr0pd34d »
Okay thanks.
You can find the whole log file in my first post.
Here is the Error Message:
004004:0000 Die Quell-Datei '/BDMV/STREAM/00000.m2ts' ist defekt oder ungültig bei Offset 23906875392.  Es wird versucht, dies zu umgehen
tp=ZeNrbpfH/X+LkJ2qtt4UsZY4/jdo1hPgA0f5l1w==
001003:0020 DEBUG: Code 0 at >*O[)m7#`m0rn3`D$L1B:121262647
001003:0020 DEBUG: Code 23 at ~O9;t-A.to)ZX:ukM`NWS:121261934
001003:0020 DEBUG: Code 0 at }t<%+Lq/ r|xud#%m3)B!:29398967
001003:0020 DEBUG: Code 3221225488 at /?gKSkHg"]L>v>+a&fGH|z'am:213131732
001003:0020 DEBUG: Code 3221225488 at ~x:~_r-KH!!jcF*d:29393953
005076:0000 Hash-Check von Datei 00000.m2ts an Offset 23911262208 fehlgeschlagen, Datei ist korrupt.
005003:0000 Titel 3 in Datei D:/Video/THE_LAST_WITCH_HUNTER/THE_LAST_WITCH_HUNTER_t03.mkv zu speichern schlug fehl
005004:0080 0 Titel wurden gesichert, 1 schlugen fehl
005037:0204 Das Kopieren wurde abgeschlossen. 0 Titel wurden gesichert, 1 schlugen fehl.
yorgo
Post by yorgo »
Thanks. Don't have much familiarity with that error code. A Google/forum search seems to indicate that it's something Mike will need to look into (ie, http://www.makemkv.com/forum2/viewtopic.php?f=7&t=7941).
dr0pd34d
Post by dr0pd34d »
yorgo wrote:Thanks. Don't have much familiarity with that error code. A Google/forum search seems to indicate that it's something Mike will need to look into (ie, http://www.makemkv.com/forum2/viewtopic.php?f=7&t=7941).
Thank you for your help anyway. ;)
I will wait for his reply and in the meantime try an older Version of MakeMKV as well
yorgo
Post by yorgo »
Couldn't hurt, right? :D
Good luck.
dr0pd34d
Post by dr0pd34d »
I have tried it with Version 1.9.10 and was greeted with the same message as before:
Fehler 'Betriebssystemfehler - {Gerät-Zeitüberschreitung} Das Zeitlimit des angegebenen E/A-Vorgangs auf hs wurde erreicht, bevor der E/A-Vorgang abgeschlossen wurde' trat auf während des Auslesens von '/BDMV/STREAM/00000.m2ts' bei Offset '23798151168'
Fehler 'Interner Fehler - Resultat des Vorgangs ist fehlerhaft (231)' trat auf während des Auslesens von '\Device\CdRom1' bei Offset '23798151168'
Fehler 'Betriebssystemfehler - {Gerät-Zeitüberschreitung} Das Zeitlimit des angegebenen E/A-Vorgangs auf hs wurde erreicht, bevor der E/A-Vorgang abgeschlossen wurde' trat auf während des Auslesens von '\Device\CdRom1' bei Offset '23798151168'
Fehler 'Betriebssystemfehler - Die angegebene Anforderung ist kein für das Zielgerät gültiger Vorgang' trat auf während des Auslesens von '\Device\CdRom1' bei Offset '23798153216'
Which should lead me to the conclusion, that the disc must be corrupted.
I will send the disc back and try it with another one later on.
I do have some other discs on the list to buy & watch so :)
