Now you see me 2 correct playlist
rose.athens
Post by rose.athens » Wed Aug 31, 2016 5:45 am
Could anyone help me find the correct playlist of the movie "Now You See Me 2"?
Thank you!
MrVideo
Re: Now you see me 2 correct playlist
Post by MrVideo » Wed Aug 31, 2016 7:02 am
More specifics about the version that you have.
rose.athens
Post by rose.athens » Sun Sep 04, 2016 8:01 am
It is the US disk, with english and spanish audio and english and spanish subs.
rexdragon
Post by rexdragon » Mon Sep 05, 2016 1:33 am
With the new anti-copying scheme called playlist obfuscation, the actual playlist number (#.mpls) is irrelevant for each region (3 or more correct playlist in 3 different discs may even apply for one region itself e.g. retail version, netflix version, redbox version). Despite that, the actual file sequence should remain the same for all discs in one region (I'm making a huge assumption here).
For the US retail version of "Now You See Me Now 2" the correct file sequence should be:
504,506,513,507,512,501,505,511,510,503,502,514,509,508,515
time length: 2:09:13
I actually ripped the file referencing the preceding title sequence and watched the mkv entirely and it seems like the correct version. You will have to go down the list file by file (left-hand panel in makemkv) and compare the title sequence (found in the lower right-hand panel) to zero in on the correct playlist. Good luck mate.
yorgo
Post by yorgo » Mon Sep 05, 2016 11:59 am
rexdragon wrote:With the new anti-copying scheme called playlist obfuscation, the actual playlist number (#.mpls) is irrelevant for each region (3 or more correct playlist in 3 different discs may even apply for one region itself e.g. retail version, netflix version, redbox version). Despite that, the actual file sequence should remain the same for all discs in one region (I'm making a huge assumption here).
I would not make that assumption, take a look at the Allegiant thread to see this is not the case: http://www.makemkv.com/forum2/viewtopic.php?f=8&t=14756
That's why it's important to know if it is a rental or purchase, where rented or purchased, and what country.
theonegod
Post by theonegod » Tue Sep 06, 2016 3:46 pm
How about for US Red
gamecaptor
Post by gamecaptor » Tue Sep 06, 2016 5:31 pm
Redbox USA. AnyDVD 8.0.4.0 says:
Java BD protection good playlists: 626
Tried to use Process Monitor 3.2 to verify but it's telling me "blocked by virtual memory" and is spitting out a bunch of different mpls numbers (i.e. it can't seem to read the correct one). This is the first time I've seen this.
shingaimav
Post by shingaimav » Tue Sep 06, 2016 5:41 pm
Does anyone have the correct playlist for Now You See Me 2 (Redbox Version)? Any help would be appreciated. Thanks!
Rabadawg211
Post by Rabadawg211 » Tue Sep 06, 2016 9:03 pm
After doing it the hard way. I am also getting 626 as the correct playlist for the US Redbox version of the movie. Segment map for this version should be:
507,508,503,506,513,510,512,505,514,504,511,509,501,502,515
FGonzales
Post by FGonzales » Tue Sep 06, 2016 9:24 pm
I'm also getting 626 for US Redox version.
507, 508, 503, 506, 513, 510, 512, 505, 514, 504, 511, 509, 501, 502, 515.
KENSAI
Post by KENSAI » Tue Sep 06, 2016 9:37 pm
Thanks so much to those of you figure this out and share it with us - I appreciate it so much! :D
PSonic
Post by PSonic » Wed Sep 07, 2016 2:04 am
I can't even get my external blu-ray drive to load up Now You See Me 2. It thinks about it for a bit and then spits it out.
Got it from Redbox.
penguinsaregood
Post by penguinsaregood » Wed Sep 07, 2016 10:26 pm
Purchased from Amazon:
Title information
Name: Now You See Me 2 (English)
Source file name: 00786.mpls
Duration: 2:09:13
Chapters count: 16
Segment count: 15
Segment map: 504,506,513,507,512,501,505,511,510,503,502,514,509,508,515
File name: Now_You_See_Me_2_t190.mkv
jrinehart76
Post by jrinehart76 » Wed Sep 07, 2016 10:28 pm
Source file 00626.mpls is also correct for BluRay Netflix version
Rydsen
Post by Rydsen » Thu Sep 08, 2016 1:01 am
Aside from using AnyDVD, how did y'all come up with 626 as the correct playlist? I've been trying to use Process Monitor like usual but it's not finding anything at all, not even a cached file. It stumped me so I just waited to see if others had better luck and it appears so.
