Numerous Errors Since v1.10.1
TolkienBard
#1 Post by TolkienBard » Fri Aug 26, 2016 9:29 pm
Last week I finally got around to ripping Person of Interst Season 5, Disc 1, only to have it repeatedly have errors regarding the first episode or, finding only 2 episodes to rip. I thought it might be my disc so I set it aside. Then I borrowed my mate's and had the same errors creep up. I then began the process of trying to rip THe Blacklist Season 3, and every disc in the season is encountering the same problem, either unable to rip one of the listed episodes, or only finding 2 episodes (out of 5) that it can decrypt/rip.
Right now I am looking at
Type: Blu-ray
Lable The Blacklist S3 D2
Protection: AACS v58
My drive has a highest AACS version of 61
I am at a loss as to how to proceed to get these discs fully ripped or recognized, as in the past, when something like this would creep in, a simple update was all that was needed. I am on the current version though, and it does not appear that the discs would subject to a higher AACS version than is currently decrypted.
TolkienBard
Re: Numerous Errors Since v1.10.1
#2 Post by TolkienBard » Fri Aug 26, 2016 9:33 pm
As I continue trying to knock out my backlog of discs to rip, I am having the same issue with Batman v Superman Ultimate Edition. I get a rather long list of
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '74913792'
Something is clearly amiss here.
yorgo
#3 Post by yorgo » Sat Aug 27, 2016 12:53 am
This is an indicator that the disc cannot be read for ripping. You may wish to check this out: https://www.makemkv.com/forum2/viewtopi ... 101#p46239
Try cleaning the disc carefully. If this does not help, there are probably issues with the disc created during mastering. Replace the disc, see what happens. Lastly, could be a drive issue; try a new drive. I have multiple internal drives specifically for this reason; what works in one may not work in another.
FYI, I've had more than one occasion where I've replaced a disc multiple times until I found one that ripped correctly.
TolkienBard
#4 Post by TolkienBard » Sat Aug 27, 2016 3:08 am
I'm going to try a new drive this weekend. I'm up to 5 discs i a row now that I am experiencing this issue with, plus the "replacement" disc for Person of Interest.
I have tried using a microfiber cloth with some distilled water on it to clean the discs and it seems to have had no appreciable effect, so I am not so fortuante as to have it be something so simple.
wastedhalo
#5 Post by wastedhalo » Tue Aug 30, 2016 12:04 pm
I have also had a difficult time ripping blu rays recently. It started out with "Gods of Egypt" which my computer wouldn't even recognize. I tried 3 copies of that disc before replacing my drive. I also updated to v1.10.1 about the same time. I've noticed that now it seems to take forever on some discs for MakeMKV to scan the drive and pull up the track list but it usually still works. The extra time might be related to the fact that I realized the MakeMKV used Java to help pick the right track on some discs so I installed the JRE. Today I failed to rip 2 discs. The first gave me a bunch of medium errors which happens sometimes, maybe it's a bad disc. The other gave me the following...
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..08AAD2F6AF49D972DC8A5E2ED3D0351E2AF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C8D975651CA41472550AE4717A759CE63B to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07ECB3593D20E1915F1043FFE994D6E8CB0 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0F2732BAFE5371120B3EE00E971209FFA61 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..073405D21A3B77FB8AF7A5346B65498ADD9 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..056B585AD0BE0A203677F5E16AFA26874B4 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0943D6980BE9833D3C16C9623BB4AE7995A to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..087BBD41326FF274E9F1DF87122E16AAA08 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00EBE3B5566347083A9302DF011D99822EC to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07FCEEB3E638D0E7B570574EE4E2A3E2CC9 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D46B4121416D8656ED19C0496B28AC74AE to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..06C9340A3E59C2A4EE1BD41C5E0BF6A0AED to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D1D226B19DE88E922B90EF9721589464B1 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0A6A0395664DB960C190D05994748F8FC8A to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B0DB5BDABB533A3FFDA67B7E82B5615A83 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00F4AD9924A3E797A4F39BB509F2867C5CE to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E92143FF106A54CDF53B74A0FD78111A15 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0F887A8789775BDF6341F3274E0F86AC934 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03B2016DD34A206E36F111F12F5BAA1A739 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03F189F4C451EA7BB48C513D4067219D2E3 to device 'SPTI:\Device\CdRom0'
Highest AACS version is v61 , MKB saved as /.MakeMKV/MKB_v61_10_Cloverfield_Lane.tgz
This was on a Blu-Ray with AACS v12
#6 Post by Woodstock » Tue Aug 30, 2016 3:16 pm
The highest AACS version your MakeMKV has seen is v61, per your log, but that might not be the highest version that the drive has seen. I received disks yesterday that have v62 on them, which seems to revoke the key MakeMKV uses.
Fortunately, neither of my drives saved the revocation list into the firmware, so I can still rip prior versions of AACS, but some drives will stop responding to ANY BD reads, if they've loaded a new revocation table.
wastedhalo
#7 Post by wastedhalo » Tue Aug 30, 2016 9:54 pm
That's very possible as the drive it fresh off amazon. Maybe it was pre-loaded with a newer AACS version. Guess I'll reinstall my old drive and use it for lower AACS version discs until the next MakeMKV update. Is there a way to check the AACS version on the drive?
#8 Post by Woodstock » Tue Aug 30, 2016 11:44 pm
As I understand it, it's not so much the AACS version, but the revocation list included with it.
I wonder if there is a way to clear the revocation table?
Zontar
#9 Post by Zontar » Sat Sep 03, 2016 11:31 pm
I encountered the mass of SCSI errors on 1.10.1. (1.10.0 would not compile for me on Fedora 24.) I backreved to 1.9.10 and the problems went away. This was under Fedora 24, so your results may vary.
angelgraves13
#10 Post by angelgraves13 » Sun Sep 25, 2016 4:32 am
Try setting a higher value for retries when copying. I had to set mine to 50 to successfully copy a scratched disc.
