Wanting to buy MakeMKV? Had a couple question.
jedity17
I have been using the beta version for a little bit to back up my dvds. I was curious when I buy full version to back up blu rays, how do i know it will work, because when i put the in now it says no disc. I just want to make sure it will work before i buy it. Does anybody if it doesn't work of there is a refund policy. Thanks for the help and time. Im guessing what im asking is do i have to have a blu ray drive on my computer. When i checked the system info i didnt see anything that said blu ray.
Re: Wanting to buy MakeMKV? Had a couple question.
The registered version is the same program, just a long-lasting authorization key. That is, you don't have to enter a new key every 60 days or so.
If you're getting "No Disk" right now, your operating system is not letting MakeMKV see when the disk is loaded, which is a separate issue.
I have NO clue what Mike's policy is on refunds.
jedity17
Ok cool thanks for your help.
wullabulla
Have you tried opening makemkv as administrator?
jedity17
Im think its because my laptop does not have a blu ray drive the dvds work fine.
