Errors Converting "The Strain" Season 1 Disc 1.
JoeInMV
Post by JoeInMV » Fri Aug 26, 2016 6:41 pm
Only one of the 4 titles on the disc was able to be converted. Below I'm pasting the log of what happened. I was hoping to be able to watch these episodes on my iPhone. I'm doing the conversion on a MacBook Pro and using an external USB3 Blu-ray drive.
I was able to convert Disc 2 of this series, and one of the titles, Season 1 - Episode 1, that won't convert plays normally on my Sony Blu-ray player.
This is the log:
Saving 4 titles into directory /Users/xxxx/
Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '10646323200'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '10646323200'
DEBUG: Code 1073741829 at +f%qQyRW~6x&R"zZ3I:121262969
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '10646323200'
DEBUG: Code 100942878 at +f%qQyRW~6x&R"zZ3I:121262969
DEBUG: Code 0 at 2Eh[BZ:!"Rv1C Et]V}E:121263291
DEBUG: Code 0 at 1>UJW,$s6O6Ec33zNC^7:121262302
DEBUG: Code 0 at 2Eh[BZ:!"Rv1C Et]V}E:213130812
DEBUG: Code 5198400 at 2Eh[BZ:!"Rv1C Et]V}E:29393286
DEBUG: Code 0 at {e)?BILU9seTNzhK|F$[":29398967
Failed to save title 1 to file /Users/xxxx/The_Strain,_Season_1_Disc_1_t01.mkv
Forced subtitles track #3 turned out to be empty and was removed from output file
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '1553657856'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '1553657856'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '1553661952'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '1553657856'
Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '1553657856'
DEBUG: Code 100864261 at +f%qQyRW~6x&R"zZ3I:121262969
DEBUG: Code 758622 at 2Eh[BZ:!"Rv1C Et]V}E:29393286
Failed to save title 3 to file /Users/xxxx/The_Strain,_Season_1_Disc_1_t03.mkv
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '8230533120'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '8230533120'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '8230535168'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '8230533120'
DEBUG: Code 4018815 at 2Eh[BZ:!"Rv1C Et]V}E:29393286
Failed to save title 4 to file /Users/xxxx/The_Strain,_Season_1_Disc_1_t04.mkv
1 titles saved, 3 failed
Re: Errors Converting "The Strain" Season 1 Disc 1.
Post by Woodstock » Fri Aug 26, 2016 8:26 pm
Your drive is having trouble reading the disk.
I know the regulars around here are getting irritated with this response, but.... :)
Clean the disk. More and more, disks coming out of packages have a thin film of chemicals from when they're being packaged that disrupts the laser, but looks perfectly clean. A damp, soft cloth will remove it, most of the time.
JoeInMV
Post by JoeInMV » Fri Aug 26, 2016 9:10 pm
I'll give it a shot when I get home, although I would have thought that a dirty disc would have failed on the Sony BDR player as well.
yorgo
Post by yorgo » Sat Aug 27, 2016 12:56 am
Not irritated at all but it might be VERY helpful to all if a sticky was created, to be referred to...
JoeInMV
Post by JoeInMV » Sat Aug 27, 2016 4:25 am
There was still one title that didn't want to convert after cleaning, then I remembered I had an older Read-only drive. Used that one and it converted the title.
Thanks for the help.
Lovely Rita
Post by Lovely Rita » Sat Aug 27, 2016 1:48 pm
+1
Registered User :wink:
Buy MakeMKV
