Empty Chapter at End of Rip?
rclongshot
Post by rclongshot » Thu Aug 25, 2016 11:34 am
Good morning, I'm attempting to rip both Ash vs Evil Dead S1 & The Walking Dead S6 and the individual episodes when ripped have an extra chapter at the end [it's just black screen, no sound]. The entirety of the episode is there, it's just that after the credits you get a couples minutes of black.
It appears that all episodes rip has the proper amount of chapters, so I can rip that and then just separate them, but curious if anyone else has experienced this empty chapter?
Thanks,
-R
yorgo
Re: Empty Chapter at End of Rip?
Post by yorgo » Fri Aug 26, 2016 5:31 am
Yes, I have experienced the same with The Walking Dead, and not just season 6. Not much to do about it so I just ignore the extra chapter.
Post by Woodstock » Fri Aug 26, 2016 11:48 am
You CAN take care of it using post-processing. Since everything I do goes through handbrake before going onto the media server, I would simply tell handbrake to ignore the last chapter. I see it more often with "DVD credits" on the last episode on a particular disk...
yorgo
Post by yorgo » Fri Aug 26, 2016 10:17 pm
Woodstock wrote:You CAN take care of it using post-processing. Since everything I do goes through handbrake before going onto the media server, I would simply tell handbrake to ignore the last chapter. I see it more often with "DVD credits" on the last episode on a particular disk...
Yes, correct, it can be taken care of with 3rd-party processing if one is so inclined (I'm too lazy to process again just to eliminate this :lol: ). But, confirming for the OP, out of the gate MakeMKV has left blank chapters which MakeMKV cannot remove.
Kyocere
Post by Kyocere » Sat Aug 27, 2016 3:37 pm
I registered just to confirm the same with Ash vs Evil Dead. As stated earlier, skipping the last chapter in Handbrake works well.
angelgraves13
Post by angelgraves13 » Sat Sep 03, 2016 8:49 pm
I just used mkvmerge and split out the last chapter that was blank. Seen this on a few blu-rays.
I also split out the first 166 frames of Narcos as it was just the annoying Netflix logo.
