Control over data rate / image quality?
garydauphin
Post by garydauphin » Wed Aug 24, 2016 12:07 am
I am using the latest version on Mac OS X 10.11. This software is tight!
Anyway, just wanted to know: is there a way for me to increase the converted data rate of the output file? I could not find any settings for changing the data rate, video size, etc.
Unclear if I am just missing some advance settings, or it is not part of the software?
Re: Control over data rate / image quality?
Post by Woodstock » Wed Aug 24, 2016 1:33 am
Changing bit rates means recoding. Tools vary in cost and complexity. I use handbrake (from handbrake.fr), but the adventurous use tools like ffmpeg to do it.
garydauphin
Post by garydauphin » Wed Aug 24, 2016 2:29 am
Thanks, but I'd rather not recode. I would simply like to have a dialog box before encoding that says "Requested Data Rate:" _____ and let me type in the bitrate I would like to shoot for. Since some bitrate is being set by the software anyway, it should not be a difficult change.
Otherwise, it gets too complicated, and one of the things I like about this tool is the simplicity.
Yugatha
Post by Yugatha » Wed Aug 24, 2016 7:01 am
You say you don't want to recode, then ask for options on recoding.
MakeMKV is a tool to extract the video and audio / subtitle streams from a disc, and store them in an MKV file. The video stream stored in the MKV file is the exact same as was on the disc (a bit for bit copy). and therefore it is impossible to increase the bit-rate of the video stream using MakeMKV (same rules for audio and subtitle stream).
The bitrate is being set by the DVD / BluRay disc (and whoever authored it to begin with), not by MakeMKV.
This is what is great about MakeMKV - it does one thing, and does it well. It doesn't try to become a one-stop shop, but works to perform its one function properly.
Chetwood
Post by Chetwood » Thu Aug 25, 2016 4:46 am
garydauphin wrote:Anyway, just wanted to know: is there a way for me to increase the converted data rate of the output file?
Why would you want that? If the BD has bitrate X, inflating it to X+something (by recoding!) does not increase the information/quality.
