10 Cloverfield Lane Errors
deperkins
Post by deperkins »
Has anyone else had any issues ripping 10 Cloverfield Lane? I cleaned the disc and am still getting the following:
MakeMKV v1.10.1 darwin(x86-release) started
Optical drive "BD-ROM hp DVDWBD TS-LB23L 0500d" opened in OS access mode.
File 00800.mpls was added as title #0
Title #00020.mpls has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00249.mpls was added as title #1
File 00250.m2ts was added as title #2
Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01007.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01008.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01009.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01010.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01011.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01066.m2ts was added as title #3
Title #01067.m2ts has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01068.m2ts was added as title #4
File 01069.m2ts was added as title #5
File 01070.m2ts was added as title #6
File 01073.m2ts was added as title #7
Title #00022.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/deperkins/Desktop
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4523950080'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '4523950080'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4524011520'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '4524011520'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '4524015616'
Failed to save title 0 to file /Users/User/Desktop/10_Cloverfield_Lane_t00.mkv
0 titles saved, 1 failed
yorgo
Re: 10 Cloverfield Lane Errors
Post by yorgo »
Try replacing the disc. Even when a disc is clean and looks "perfect", it may have mastering errors that prevent ripping.
Did you have the laptop plugged in and charging when you did the rip? The drive you are using pulls power from the USB chip in the computer, and can have issues when spinning full speed if there is insufficient USB power.
Other than that, the same symptoms can come from a dirty disk, even when it "looks clean and perfect". I always wipe a problem disk down with a clean, damp, soft cloth when I get errors like this. Unless the disk is in really bad shape, that usually takes care of the problem.
botazefa
Post by botazefa »
10 Cloverfield Lane worked for me on 1.10.0 and Linux
deperkins
Post by deperkins »
Yeah, my issues were resolved last night after really really really wiping off the disc. Thanks everyone.
