[SOLVED] - DTS HD Master audio rips as 2 channel
Jailer
Post by Jailer » Sun Aug 21, 2016 3:21 am
Since updating to the latest release 1.10.1 all my Blu Ray rips containing DTS HD MA show as 2 channel audio in the metadata. This is causing playback issues with my media server and the audio is defaulting to the DTS core track.
Is anyone else experiencing this behavior?
yorgo
Re: Bug report - DTS HD Master audio rips as 2 channel
Post by yorgo » Sun Aug 21, 2016 12:23 pm
Can you be more specific? Which Blu-Rays, versions, etc? How are you seeing "DTS HD MA show as 2 channel audio in the metadata", using playback software, AV receiver, a file checker like MediaInfo? I've not experienced this with 1.10.1, and I test everything I rip with MPC-HC first before it goes on my server then, when it's time to watch, also check what the AV receiver says; NPF.
Jailer
Post by Jailer » Sun Aug 21, 2016 11:52 pm
The DTS MA track is showing up as "unkown" with the core track showing as 2 channel. The file properties also show as 2 channel audio. For example I'll use A Hologram For The King ripped from my blu ray disk.
If I load the encoded file back into Handbrake it shows the audio as DTS-HD MA 5.1 channels.
Handbrake was used to encode, the media info is listed below. Not sure if this is a handbrake issue or a makemkv issue. The only thing that has changed was I updated to the latest version of makemkv, my settings in Handbrake are untouched from previous encodes. Handbrake is set to DTS HD passthrough and has worked previously without issue.
General
Complete name                            : Y:\Movies\A Hologram For The King.m4v
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (isom/iso2/avc1/mp41)
File size                                : 6.25 GiB
Duration                                 : 1 h 38 min
Overall bit rate                         : 9 109 kb/s
Movie name                               : A Hologram for the King
Encoded date                             : UTC 2016-08-19 11:10:02
Tagged date                              : UTC 2016-08-19 11:10:02
Writing application                      : HandBrake 0.10.5 2016021100
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 4 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Bit rate                                 : 5 656 kb/s
Width                                    : 1 280 pixels
Height                                   : 536 pixels
Display aspect ratio                     : 2.40:1
Original display aspect ratio            : 2.40:1
Frame rate mode                          : Variable
Minimum frame rate                       : 23.810 FPS
Maximum frame rate                       : 24.390 FPS
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.344
Stream size                              : 3.88 GiB (62%)
Writing library                          : x264 core 142 r2479 dd79a61
Encoding settings                        : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Menus                                    : 3
Audio
Format                                   : DTS
Format profile                           : MA / Core
Mode                                     : 16
Format settings, Endianness              : Big
Codec ID                                 : A9
Bit rate mode                            : Variable / Constant
Bit rate                                 : Unknown / 1 509 kb/s
Channel(s)                               : 2 channels
Channel(s)_Original                      : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Frame rate                               : 93.750 FPS (512 spf)
Compression mode                         : Lossless / Lossy
Stream size                              : 2.36 GiB (38%)
Title                                    : Surround / Surround
Menus                                    : 3
Menu
Codec ID                                 : text
Menu For                                 : 1,2
00:00:00.000                             : Chapter 1
00:05:09.559                             : Chapter 2
00:12:09.854                             : Chapter 3
00:17:35.429                             : Chapter 4
00:24:02.315                             : Chapter 5
00:32:05.465                             : Chapter 6
00:35:27.125                             : Chapter 7
00:43:32.985                             : Chapter 8
00:49:44.314                             : Chapter 9
00:53:59.569                             : Chapter 10
01:00:51.231                             : Chapter 11
01:08:52.002                             : Chapter 12
01:11:05.386                             : Chapter 13
01:16:52.191                             : Chapter 14
01:24:03.872                             : Chapter 15
01:31:58.513                             : Chapter 16
Bit rate mode                            : VBR
yorgo
Post by yorgo » Mon Aug 22, 2016 1:18 am
What does the original BD-to-MKV rip look like in MediaInfo? Your first and third images only show the compressed file information (.m4v).
Your second one from Handbrake seems to indicate the wanted audio track is there so the fault would seem to fall on Handbrake and not MakeMKV but it would be helpful to know what the original MKV contained before any more conclusive answer can be given.
Jailer
Re: [SOLVED] - DTS HD Master audio rips as 2 channel
Post by Jailer » Tue Aug 23, 2016 11:11 am
Figured out my problem. Turns out it's a bug in the current version of Handbrake. Everything that I've encoded since my new computer build and use of the latest stable version of Hanbrake shows 2 channel audio when using DTS-HD passthrough. Turns out it's not a problem with makemkv at all. Sorry for the confusion.
