SALT "Deluxe Extended Edition" BD 2010 Region ABC Germany
adolder
Post by adolder »
Hello!
2010 release Blu-Ray movie "SALT" fails...partially - able to decrypt smaller pieces, but not the main movie file on full disk run. I've tried this over time with several versions of MakeMKV. Here are the logs and system settings from today's attempt (August 19-20, 2016)
The FORUM system has a limit of 60000 characters, but my log entries in this post add up to 73908. In order to succeed at posting this message I have remove redundant log entries to reduce the message size.
My system:
OSX 10.6.8
MMKV 1.10.1
RAM 24GB
MAC Pro 2009 2x2.8GHz Quad-Core Intel Xeon
DRIVE INFORMATION
OS device name: /dev/rdisk4
Product: BD-RE WH12LS39
Revision: 1.00
Serial number: K87C1UXXXXXXXXXxxxxx
Firmware date: 2011-11-08 12:34:56
Bus encryption flags: 1F
Highest AACS version: 57
DISC INFORMATION
Label: SALT
Timestamp: 2010-10-22 13:10:25
Data capacity: 46.21 Gb
Disc type: BD-ROM
Number of layers: 2
FIRST READ SOURCE DISC LOG
MakeMKV v1.10.1 darwin(x86-release) started
Optical drive "DVD+R-DL OPTIARC DVD RW AD-7170A 1.NC" opened in DASPI v1.3 mode.
Optical drive "BD-RE HL-DT-ST BD-RE WH12LS39 1.00" opened in DASPI v1.3 mode.
Title #00102.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00095.mpls has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00096.mpls has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00001.mpls was added as title #0
File 00003.mpls was added as title #1
File 00005.mpls was added as title #2
File 00002.mpls was added as title #3
File 00004.mpls was added as title #4
File 00006.mpls was added as title #5
Title 00045.mpls is equal to title 00001.mpls and was skipped
Title 00046.mpls is equal to title 00003.mpls and was skipped
Title 00047.mpls is equal to title 00005.mpls and was skipped
File 00040.mpls was added as title #6
Title #00000.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00502.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00503.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00504.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00205.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #04999.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00105.m2ts was added as title #7
File 00106.m2ts was added as title #8
File 00107.m2ts was added as title #9
File 00108.m2ts was added as title #10
File 00109.m2ts was added as title #11
File 00110.m2ts was added as title #12
File 00111.m2ts was added as title #13
Title #00140.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00113.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00114.m2ts was added as title #14
Title #00115.m2ts has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00116.m2ts was added as title #15
Title #00117.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00118.m2ts was added as title #16
Title #00119.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00120.m2ts was added as title #17
Title #00121.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00122.m2ts was added as title #18
Title #00123.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00124.m2ts was added as title #19
Title #00125.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00126.m2ts was added as title #20
Title #00127.m2ts has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00128.m2ts has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00129.m2ts has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00130.m2ts was added as title #21
File 00131.m2ts was added as title #22
File 00132.m2ts was added as title #23
Title #00133.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00134.m2ts was added as title #24
Title #00135.m2ts has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00136.m2ts was added as title #25
Title #00137.m2ts has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00138.m2ts has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00139.m2ts was added as title #26
Title #00143.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00144.m2ts has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00145.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00146.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00147.m2ts has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00148.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00149.m2ts has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00150.m2ts was added as title #27
Title #00151.m2ts has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00152.m2ts was added as title #28
File 00153.m2ts was added as title #29
Title #00154.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00155.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00156.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00157.m2ts has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00158.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00159.m2ts was added as title #30
File 00160.m2ts was added as title #31
Title 00001.mpls is equal to title 00040.mpls and was skipped
DISC FILE STRUCTURE TREE (IMG)
RUN LOG
rror 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '154402816'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '154402816'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00130.m2ts' at offset '154398720'
Failed to save title 5 to file /Volumes/Movies/Salt/Salt_t05.mkv
Forced subtitles track #3 turned out to be empty and was removed from output file
Forced subtitles track #5 turned out to be empty and was removed from output file
Forced subtitles track #7 turned out to be empty and was removed from output file
Forced subtitles track #9 turned out to be empty and was removed from output file
Forced subtitles track #11 turned out to be empty and was removed from output file
Forced subtitles track #13 turned out to be empty and was removed from output file
Forced subtitles track #17 turned out to be empty and was removed from output file
Forced subtitles track #19 turned out to be empty and was removed from output file
Forced subtitles track #23 turned out to be empty and was removed from output file
Forced subtitles track #25 turned out to be empty and was removed from output file
Forced subtitles track #27 turned out to be empty and was removed from output file
Forced subtitles track #29 turned out to be empty and was removed from output file
Forced subtitles track #31 turned out to be empty and was removed from output file
Forced subtitles track #33 turned out to be empty and was removed from output file
Forced subtitles track #35 turned out to be empty and was removed from output file
Forced subtitles track #37 turned out to be empty and was removed from output file
Forced subtitles track #39 turned out to be empty and was removed from output file
Forced subtitles track #43 turned out to be empty and was removed from output file
Forced subtitles track #45 turned out to be empty and was removed from output file
Forced subtitles track #47 turned out to be empty and was removed from output file
Forced subtitles track #49 turned out to be empty and was removed from output file
Forced subtitles track #51 turned out to be empty and was removed from output file
Forced subtitles track #53 turned out to be empty and was removed from output file
Forced subtitles track #55 turned out to be empty and was removed from output file
Forced subtitles track #57 turned out to be empty and was removed from output file
Forced subtitles track #15 turned out to be empty and was removed from output file
Forced subtitles track #21 turned out to be empty and was removed from output file
Forced subtitles track #41 turned out to be empty and was removed from output file
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00130.m2ts' at offset '155320320'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '155320320'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00130.m2ts' at offset '155449344'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '155449344'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '155451392'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00130.m2ts' at offset '155578368'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '155578368'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '155582464'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00130.m2ts' at offset '155645952'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '155645952'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '155648000'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00130.m2ts' at offset '155910144'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '155910144'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00130.m2ts' at offset '156235776'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '156235776'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '156237824'
Failed to save title 20 to file /Volumes/Movies/Salt/Salt_t20.mkv
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00131.m2ts' at offset '497725440'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '497725440'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '497729536'
Failed to save title 21 to file /Volumes/Movies/Salt/Salt_t21.mkv
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00132.m2ts' at offset '329644032'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '329644032'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '329646080'
Failed to save title 22 to file /Volumes/Movies/Salt/Salt_t22.mkv
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00134.m2ts' at offset '131334144'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00134.m2ts' at offset '134873088'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '134873088'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00134.m2ts' at offset '135198720'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '135198720'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '135200768'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00134.m2ts' at offset '135524352'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '135524352'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '135528448'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00134.m2ts' at offset '135856128'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '135856128'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00134.m2ts' at offset '136181760'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '136181760'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '136183808'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00134.m2ts' at offset '136181760'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00134.m2ts' at offset '136507392'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '136507392'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '136511488'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00134.m2ts' at offset '136507392'
Failed to save title 23 to file /Volumes/Movies/Salt/Salt_t23.mkv
Re: SALT "Deluxe Extended Edition" BD 2010 Region ABC German
The errors you are getting are consistent with a disk that isn't completely clean. Your drive can almost read parts of the movie with retries, but there are some areas that simply aren't readable.
First step would be to clean the disk with a damp, soft cloth.
adolder
Post by adolder »
Woodstock! Thank you for your quick reply and advise.
Still having problems though.
The disc is brand new, no scratches, very clean. I checked my drive to make sure it is clean. It is.
Nonetheless, I polished the disc and started a new session, but it got stuck and failed about half way finished.
I wonder if it has something to do with the structure of the disc in terms of how it plays back. The packaging claims "three versions": original cinema. director's cut, and extended version. When you look at the title list generated by MakeMKV, you will see that there are six main titles each at 25GB each - that's 150GB total which of course is impossible on a 50GB Blu-ray disk. So, I wonder if to accommodate the three versions, there is some "track jumping" so that the extra versions can be assembled on the fly, rather than have three complete muxed files, which even three would be impossible at that file size.
So if my theory is correct, then maybe when the MakeMKV program encounters something in the structure that tells the Blu-ray to switch tracks or something (which would be fine for the BD playback), but maybe confuses MakeMKV which is trying to march forward on the same track...just a theory.
Thank you in advance for any advise you may have.
yorgo
Post by yorgo »
You may wish to read up on "seamless branching" on how it works: https://en.wikipedia.org/wiki/Seamless_branching. It has no bearing on the problem you're experiencing.
Per this FAQ (/faq/item/7), the problem appears to be your specific disc. Try cleaning again and, if that doesn't work, replace the disc. FYI, even when a disc looks clean, it could still have unseen mastering issues.
adolder
Post by adolder »
Hello Yorgo!
Thank you for your advise. I will read the articles and try replacing the disc.
Regards,
AHD
