SCSI Errors every single time
gordonf238
Post by gordonf238 »
Hi all,
I've been using MakeMKV for years, but in recent months began receiving a ton of SCSI errors while ripping Blu-Rays. These are brand new discs from Amazon that I had purchased, without a single smudge on them. I have upgraded to the latest version of OSX, and purchased a different Blu-Ray drive (Pioneer BDR-XS06 USB 3.0). I have additionally tried to use my Mac Mini and iMac, all to no avail.
If I'm lucky, one out of 10 Blu-Rays actually rips successfully.
Since I can't seem to isolate the problem, can anyone here recommend their favorite Blu-Ray drive to use for OSX ripping?
I'm a bit at a loss as to why my setup, which has worked fine for years, and would only throw out SCSI errors when the disc was clearly damaged has suddenly become completely useless.
Many thanks everyone.
Re: SCSI Errors every single time
Maybe if we could see what type of SCSI errors.... Different problems have different symptoms.
Are there the same type of failures with DVDs, or is it JUST BDs?
gordonf238
Hi, and thanks for your reply. Here is the error report while trying to READ the disc (not rip it). This is a brand new War of the Worlds Blu-Ray purchased off Amazon, without so much as a fingerprint on it.
MakeMKV v1.10.1 darwin(x86-release) started
Optical drive "BD-RE PIONEER BD-RW BDR-XS06 1.01d" opened in OS access mode.
Title #00008.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00055.m2ts' at offset '0'
I'm just going to buy a few Blu-Ray players off Amazon and see if some of them have a bigger success rate. This is beyond frustrating.
I have no trust for "new" equaling "clean" since I opened a brand new BD and had the humidity in the room show me the outline of the suction cups that had been used to move the disk from the production equipment into the packaging... If it gives ANY errors during the initial rip, it gets wiped down.
Getting errors reading stream files at the first sector is not unheard of, but not usual either. And doing it during the initial read of the disk pretty much kills the idea that the USB isn't providing sufficient power, since the drive isn't going to be spinning that fast yet.
It will be interesting to see what results you get with a different drive. Pioneer drives have both lovers and haters out there.
gordonf238
Hi
Reporting back. Tried two Blu-Ray drives, brand new off Amazon. Also ordered a new copy of War of the Worlds Blu-Ray. Discs look fine, without any smudges. Brand new. Yet this is the error report. Got the same thing when trying to use the drives on my Mac Mini.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00055.m2ts' at offset '2917251072'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00055.m2ts' at offset '27816855552'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00055.m2ts' at offset '129024'
Title #00020.mpls was skipped
File 00028.mpls was added as title #0
Title #00002.mpls has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.mpls was skipped
Title #00000.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00055.m2ts was skipped
File 00056.m2ts was added as title #1
File 00057.m2ts was added as title #2
File 00058.m2ts was added as title #3
File 00060.m2ts was added as title #4
File 00061.m2ts was added as title #5
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00062.m2ts' at offset '0'
Title #00062.m2ts was skipped
File 00063.m2ts was added as title #6
File 00064.m2ts was added as title #7
File 00065.m2ts was added as title #8
File 00066.m2ts was added as title #9
File 00067.m2ts was added as title #10
Title #00068.m2ts has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00074.m2ts' at offset '0'
Error 'Internal error - Operation was cancelled (112)' occurred while reading '/BDMV/STREAM/00074.m2ts' at offset '0'
Title #00074.m2ts was skipped
Title #00076.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01000.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01001.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
The errors still point to a problem with the disk itself. Where they occur is in the area of the directory of the disk, near the hub. The times I've seen errors in this area, I sometimes found cracks in the hub. Although my copy of the Last Starfighter BD has a chunk broken out of the hub, and decodes just fine. :roll:
